Tiller howse 70 wide tiller - rebuild or replace rusty pto knuckle
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #11
That looks a whole lot better than I was picturing from your description, at worst case a new set of friction discs and your good to go.
Received the replacement u joint from Howse Implement in Monday's mail and put it all together Monday evening. Rebuilt PTO u joint works perfect.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #13
Good Afternoon. Question to see if you may know since it seems like our exact same tiller. I’ll post a picture of the part that broke out. I think it’s friction plates but not 100% sure.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #14
NurseFarmer, I don't have that tiller but the piece in your hands sure looks like a broken piece of friction plate from the slip clutch. Should be an easy replacement part if you have a dealer somewhere.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #15
Yep that is the clutch so if you hit something hard it will slip and not break the gear box or something else.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #16
Tractor supply has some the snap rings are included
willy
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #18
That's what is usually inside the yoke and when they are
rusted out or wore out that item is needed to replace the
old one. I have done enough of them
willy
BUSH HOG 5' SQULAR ROTARY MOWER (A52708)
BUSH HOG 5' SQULAR...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
2012 MACK GU713 (A58214)
2012 MACK GU713...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
