Tiller howse 70 wide tiller - rebuild or replace rusty pto knuckle
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #11
That looks a whole lot better than I was picturing from your description, at worst case a new set of friction discs and your good to go.
Received the replacement u joint from Howse Implement in Monday's mail and put it all together Monday evening. Rebuilt PTO u joint works perfect.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #13
Good Afternoon. Question to see if you may know since it seems like our exact same tiller. I’ll post a picture of the part that broke out. I think it’s friction plates but not 100% sure.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #14
NurseFarmer, I don't have that tiller but the piece in your hands sure looks like a broken piece of friction plate from the slip clutch. Should be an easy replacement part if you have a dealer somewhere.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #15
Yep that is the clutch so if you hit something hard it will slip and not break the gear box or something else.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #16
Tractor supply has some the snap rings are included
willy
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #18
That's what is usually inside the yoke and when they are
rusted out or wore out that item is needed to replace the
old one. I have done enough of them
willy
202477 (A54757)
202477 (A54757)
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
BELSHE DT-235 (A55745)
GooseNeck Trailer (A52377)
GooseNeck Trailer...
RV Hitch (A50121)
RV Hitch (A50121)
