Tiller howse 70 wide tiller - rebuild or replace rusty pto knuckle
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #11
That looks a whole lot better than I was picturing from your description, at worst case a new set of friction discs and your good to go.
Received the replacement u joint from Howse Implement in Monday's mail and put it all together Monday evening. Rebuilt PTO u joint works perfect.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #13
Good Afternoon. Question to see if you may know since it seems like our exact same tiller. I’ll post a picture of the part that broke out. I think it’s friction plates but not 100% sure.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #14
NurseFarmer, I don't have that tiller but the piece in your hands sure looks like a broken piece of friction plate from the slip clutch. Should be an easy replacement part if you have a dealer somewhere.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #15
Yep that is the clutch so if you hit something hard it will slip and not break the gear box or something else.
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #16
Tractor supply has some the snap rings are included
willy
   / howse 70 wide tiller - rebuild or replace rusty pto knuckle #18
That's what is usually inside the yoke and when they are
rusted out or wore out that item is needed to replace the
old one. I have done enough of them
willy
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
2018 MACK CHU613 DAYCAB (A55745)
2018 MACK CHU613...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
