How to test safety switches
/ How to test safety switches #1
jayhawk238
Featherville Idaho
2004 Kubota L5030
What is the easiest way to test the safety switches on my L5030? Having a no start problem and need to see if one of the switches is the cause. We think it might be a safety switch or maybe a starter solenoid. Can still start the tractor but have to by hot wiring the starter which bypasses all the safety switches. Plus I can't use my remote start!! šŸ˜‚;)šŸ™ƒ
/ How to test safety switches #2
Easiest would probably be to use a jumper wire, or pull the connector and jump it with a paper clip or something. Most of them seem to be fairly easy to get to.
The only one I've ever had any issues with was on the L3800, when the one for the forward/reverse pedal apparently didn't go to the neutral position like it should. So that was more of a mechanical issue than electrical.
/ How to test safety switches #4
You can test individual switches with an ohmmeter if you can find them. As Jayhawk said though the problem could be mechanical. My problem was the rod upon which the seat pivots came loose on one end causing an intermittent problem.
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2016 Ford F-150 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
