How to "store" logs prior to cutting
   / How to "store" logs prior to cutting #11
Re: How to "store" logs prior to cutting
I don't know how relevant it is for you, but with some species of log here I have to spray them with an insecticide to stop borers getting in. Once they dry they are fine, just that initial period from when they are cut and there is plenty of moisture in the wood.
   / How to "store" logs prior to cutting #12
Get them off the ground, Also with the bark on (as said)They will rot fast.If your saving them for fire wood you must split them, If your going to saw them for lumber cover them with old tin roofing. I use this it works great.
Army Grunt
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
1608 (A57192)
1608 (A57192)
