How to "store" logs prior to cutting
   / How to "store" logs prior to cutting #11
Re: How to "store" logs prior to cutting
I don't know how relevant it is for you, but with some species of log here I have to spray them with an insecticide to stop borers getting in. Once they dry they are fine, just that initial period from when they are cut and there is plenty of moisture in the wood.
   / How to "store" logs prior to cutting #12
Get them off the ground, Also with the bark on (as said)They will rot fast.If your saving them for fire wood you must split them, If your going to saw them for lumber cover them with old tin roofing. I use this it works great.
Army Grunt
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
FORD F-250 CREW CAB TRUCK (A59823)
FORD F-250 CREW...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
