How to remove this fuel filter?
/ How to remove this fuel filter? #21
I would be afraid of the screwdriver slipping and possibly damaging something. I have a large pair of channel locks that I would try first.
It is such a light tap that even when it slips off it does not hurt a thing. I use that technique on many things that is in a tight spot. On the tractor in the video it would take 30 minutes or more to disassemble enough stuff to use pliers.
/ How to remove this fuel filter? #24
I made a short video on the screwdriver technique. Hope this helps.
Good, but next time turn the phone 90 degrees from Portrait to Landscape orientation, for a better video.
/ How to remove this fuel filter? #25
Normally I would turn it landscape. I could not get the phone to stay propped that way.
/ How to remove this fuel filter? #26
I have absolutely no problem figuring out which side to remove. Instead of the right side, I should have said the correct side, for those that cann,t figure out something so simple.
/ How to remove this fuel filter? #28
A larger 16“ pipe wrench will fit over the hose and give enough grip on the ring to remove it. Smaller Chanel locks should fit inside of the hoses. Larger ones should fit over the hoses. The screw driver or punch method will also work well. Strap wrenches will also work. The retaining ring really does not need protection from wrenches!
Lots of options that work but if you really try things can be complicated to the frustration/breakage point.
Just be careful and don’t apply enough pressure to break the filter housing off!!
As per Rick b’s advice.
/ How to remove this fuel filter? #29
A piece of wood with a piece of rubber stappled/nailed/screwed
to it gently tap with small hammer should work
just fine no slippy can hold wood with hand and not
even hurt yourself and you won't damage a thing!;)
willy
/ How to remove this fuel filter? #31
threads like this give me less faith in humanity...
/ How to remove this fuel filter? #32
I have that on my tractor.... I've used a strap wrench for the past five years...no problems getting it off and on.
/ How to remove this fuel filter? #33
It looks so nice and easy until you realize the two rubber lines run right down the ring making spanner or channel lock fit nicely. How'd you make out?
/ How to remove this fuel filter? #34
/ How to remove this fuel filter? #35
Some filters are make so you can use these I
like them. Put your ratchet on cup type and presto
just like removing a bolt
willy
That's great when the part the cup grips is threaded. This one isn't. Good in this instance for breaking the bowl and wadding up the o-ring if you're unlucky enough to have the cup actually fit the bowl.
/ How to remove this fuel filter? #36
I'm guessing the textured ring is unscrewed - is there a tool for this or do I just grab it with some channel-lock pliers?View attachment 712437
Channel locks 1/4 turn counter clockwise. Loosen by hand from there. The cup will likely stick in the housing because the o ring is old and compressed. Don't forget new o ring when reinstalling. Leave the aluminum ring a little loose and turn ignition to prime fuel through the cup. The you can probably hand tighten
2005 Kawasaki STX-12F (A64127)
2005 Kawasaki...
Ammann AV33E Roller (A65579)
Ammann AV33E...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
