Dirt Moving How should I clear this brush?
   / How should I clear this brush? #11
My first choice would be a skid steer with a forestry mulcher attachment. Second choice would be a brush hog followed by spraying with generic Roundup as new growth appears. It's a lot less spraying and easier to kill new growth as it sprouts up rather than spaying old growth bushes and saplings.
Or repeated mowing as some suggest. But it definitely takes much longer to kill by just mowing alone. If anyone has poison oak or poison ivy, I wouldn't get anywhere near it with a mower if a person is as sensitive to it as I was.
   / How should I clear this brush? #12
Mowing is good for controlling brush but will create more sun for Blackberries.
It would be helpful to know your location. Blackberries in Florida or Georgia are a much different case from Blackberries in the Pacific Northwest.
I favor the herbicide Crossbow or Rural King's equivalent 'Crossroad'. Crossbow/Crossroad is 34.4% 2,4-D enhanced with 16.5% Triclopyr herbicide, with Blackberries specifically as a target. 2,4-D in general is for Broadleaf Weeds, which is Blackberries.
All 2,4-D herbicides are most effective when the target weeds are growing vigorously. This means Spring or Fall in most areas. The soil should be moist. Ideally, apply herbicide 24 hours before a soaking rain. Soaking rain carries some Crossbow from the leaves down to the roots.
Using Crossbow/Crossroad over ungrazed pasture in a one gallon sprayer in North Florida I have had 50% Blackberry kill after one application and almost 100% kill after a second application a month later. Pasture grass yellows a bit but recovers.
Read the herbicide directions, FOLLOW THE DIRECTIONS. Do not create home brew herbicide mixtures.
Bathe and wash clothes as soon as practical after spraying.
Crossbow is a non-selective post-emergent herbicide that targets woody plants and brush such as blackberries and poison oak, as well as annual and perennial broadleaves, while leaving grasses unharmed. Crossbow achieves excellent control of woody plants and brush and can be applied by all types of sprayers, from hand-held models to tractor-mounted spray rigs. Except for lactating dairy animals there are no grazing restrictions following the application of Crossbow Herbicide. Crossbow is rainfast within two hours after application.
This is Not to be applied to home lawns.
Note: Due to New California State restrictions, this Can Not be Sold in California.
   / How should I clear this brush? #13
What would be cost differents between... Mini excavator, skid steer or mulcher? Plan to rent one for a few days or week... compare to having dozer do the work?
Probably about the same to rent a skid steer or mini. The mulcher is probably double or 3 times as high assuming you can even get one.
   / How should I clear this brush? #14
How about getting a ratchet rake and ripping it out by the roots?
   / How should I clear this brush? #16
The only way I tamed my blackberries was to mow and keep mowing.
Mowing is the answer here too. For us mowing three or four times each summer turns the area into weedy grass in a couple years.
gg
Don't forget to sing the mowing song as you work.
Mow, mow, mow your brush
Gently near the stream
Merrily, merrily, merrily, merrily
It will look a dream
Bruce
   / How should I clear this brush? #17
gg
Yep. Couple mowings and the grass will take over
Thanks for all the good guidance. Problem is, mowing isn't really an option for me. Pictures may not do justice but the ground is so covered in debris it would be a nightmare to mow through (take a look at the middle photo for reference). I don't own a rider but imagine that's what you all are referring to, given the condition of the ground, you guys think a rider can handle that type of terrain? And what type of sapling diameter can a powerful rider take on, like in the 20-22hp range.
Answering some of the other questions, my location is New Hampshire, cold season is long and I'm JUST starting to get early signs of buds on trees.
Cost. Mini excavator and skid steer are about the same at around $300 a day and $1,100 a week. To this point I've just assumed all the sublevel roots need to be ripped up to control the growth.
Excavator and skid steer rentals will run me about $300 a day or $1,000 a week. I consulted a landscaping company who quoted me around $1,000 a day, with a whole day needed to clear large stumps so his big claw could run straight through. Then 2 days to clear and pile debris. Rental route $800-$1,000, contract it out $2,800-$3,200... womp womp
   / How should I clear this brush? #20
My location is New Hampshire. Cold season is long. I'm JUST starting to get early signs of buds on trees.
Enter your New Hampshire location in your T-B-N PROFILE, so your location shows with every post you author.
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
Sedan (A59231)
Sedan (A59231)
Chemical Containers Tank (A57148)
Chemical...
