How old is your Kioti tractor?
   / How old is your Kioti tractor? #21
Well, I may as well toss a photo up as well.
   / How old is your Kioti tractor? #22
I bought mine in December of 24 and am at about 50 right now. Hopefully next week I'll have a chance to do my 50 hour maintenance, and things might be dried up enough to get where I need to go.
   / How old is your Kioti tractor? #23
Bought my CK30 new in 2010. 900 hrs on it now. Only issue i've had is ignition switch had to be replaced. About all it its used for is mowing my 7 ac yard/fields and hauling mulch now and then. I really like it.
   / How old is your Kioti tractor? #24
RX7320 bought new Aug 2015. 500 or so hours. No issues others than the idiot owner over tightening the oil drain pan bolt and stripping it out. Oversized Dorman drain plug to the rescue.
   / How old is your Kioti tractor? #26
2005 CK30hst w/backhoe
A couple of issues, promptly taken care of by Kioti. One was even out of warranty.
Have replaced most hydraulic seals.
Recent fire burned the seat and loader controls and a few other things.. lights, control cover pieces etc.. (My tractor was the only thing that lived thru it because I pulled it out before we ran..) Backhoe did not make it...
Just got done replacing the loader controls including the cables.
Would definitely buy Kioti again. It has served me well, very reliable..
   / How old is your Kioti tractor? #27
I bought an Rx6010C with FEL , just turned over 529hrs today. Replaced 2 clutch cables ( not a good design) , fuel tank leak (plastic tank 😔) $500 for a new one. I took it off, drivers side, patched it and put it back on, only a seep now. It’s an ok tractor, but I grew up on AG tractors and there’s a big difference, but this does what I need it to, so I can live with it.
   / How old is your Kioti tractor? #28
Funny, i had to replace the stupid little switch on the parking brake lever because light was not lighting on dash when engaged, and i didnt want to occasionally operate tractor with brake on. Not only was it an expensive part ($90) but man, took nearly 1.5 hours to install. They designed that bracket that holds the latching device so securely, it was amazing. Just getting to the bolts was nearly impossible. I think they designed this latching device to hold the brakes of a DC10. I do like the fact that they tend to overbuild the DK Series. Everytime i have to dig into something, im amazed as to how well and heavily built it is.
Id buy another in a heart beat.
   / How old is your Kioti tractor? #29
"Driver's side"...? :unsure: ;)
   / How old is your Kioti tractor? #30
Well, mine has 1.6 hours on it. New CK3520 can with backhoe. Sold my CX2510 because I really wanted the backhoe and felt that the CX was under powered.
Jack Daniels Metal Truck (A57454)
Jack Daniels Metal...
296385 (A57192)
296385 (A57192)
Kubota B2601 Utility Tractor (A57453)
Kubota B2601...
Towable Diesel Generator (A59228)
Towable Diesel...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
