How much to charge/
/ How much to charge/ #41
Not true. At least in my area.
Here is bing of my house. (if you can even make anything out)
It is by far the worst of them. Definatally NOT what weather.com uses as you can clearly see.
Interesting. When I pull up weather.com, it clearly has Bing written in the bottom right corner.
Is that the Bing with Bird's Eye turned on? It looks like just their regular aerial. When I pull up Central OH, it has full Bird's Eye coverage.
/ How much to charge/ #42
Its because I live so far out in the sticks. Bing is good in the city for sure.
Try this and I think you will see what I mean. Go to bing maps, and type in 43334 zip code. Zoom all the way in on that zip. this should put you at the intersection of SR229 and bennington-harmony central road. Once zoomed ALL the way in, follow benningtion-harmony to the north. See what happens after the second road? I live in an area somewhere north after it turns to low-resolution.
And I also dont like how the bing scrolls. Like if zoomed in all the way and trying to follow a road or something. It is jumpy and erratic.
/ How much to charge/ #43
And you are right, I do see the bing on the weather map. So now I have to ask why is the weather map more current?? Or what am i doing wrong in bing?
/ How much to charge/ #44
AH-HA. I figured it out. Bing WITHOUT birds-eye on is the same as weather. But turning birds-eye on makes it go to crap in my area.
Also, the birds-eye is more out of date even in the city.
There is a menards being built close to my work. Birds-eye dont even show it. Aerial shows it as of about a few months ago.
/ How much to charge/ #45
I don't like Bing as my first choice either. I was hoping that weather.com was using something I hadn't seen before. :confused3:
Oh well....
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
karcher pressure washer (A61567)
karcher pressure...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
