How much to charge/
/ How much to charge/ #1
walterc
Rozet, Wy
Kubota
Hi, it's been awhile since I've done other than read other posts, but when I have a problem, this is my go to place.
Any way, there's a guy in the area that needs 100 acres of weeds mowed down. He initially asked to rent my tractor and mower, but I don't do that. My theory is, if it gets broke, and I'm in the seat, it's my doing. If someone else is driving and it gets broke, there will probably be feelings that i don't want to deal with.
Any way, I told him I could mow it for him, but I'm not sure how long to estimate for it, and how much to charge.
I have a 27 HP Kubota and a Deere 5' brush mower. I was thinking I could get it done over a weekend, but I'm not sure since I've never mowed that much land.
Any ideas?
Thanks!!
/ How much to charge/ #2
Thats going to be a 4-5 day job. Im getting about an acre an hr with 50hp 6ft deck.
/ How much to charge/ #3
If you were to drive 4 mph non stop, you would cover 2.4 acres per hour. This is continuous driving, does not take into account turning around on ends, breaks, re-fueling, etc. More realistic would be 2 acre per hour. Remember, this is at 4 mph, you will have to re-figure at your speed.
/ How much to charge/ #4
It will take much longer than a weekend.
Here's a handy mowing calculator to help give you an idea of mowing time required.
TractorData.com - Mowing with tractors
I usually figure 3 mph to get a good clean mowing done.
with a 60" mower, you will probably be mowing about 54" at a time after the initial 60" pass...
Mowing 100 acres with a 5' mower @ 3mph will take ~67.2 hours
/ How much to charge/ #5
... more if you "find" any barbed wire or irrigation pipe. I'd want to walk those acres, looking for debris and obstructions (holes, stumps, etc), before I agreed to a price.
/ How much to charge/ #6
I do our "pasture" in our JD 950 in second gear. That works out to 2.2 mph. Couldn't imagine mowing much faster that 3 mph.
So that works out to a little more than 1 acre/hour.
Twenty seven acres? $2000? $3000?
/ How much to charge/ #7
I mow as a part time job. You should figure on about 1.5-2 acres per hour and about 7 hours a day is about all I can stand. If all goes well, and it rarely does, figure on a little less than 15 acres a day. 100 acres will take about 7 days and be worth at least $1500. You will run through at least $300 in fuel.
/ How much to charge/ #8
I don't know your market, but that works out to $24.50/ hr for a rig, operator, profit etc. You could easily justify tripling those rates. It is better to charge more and work less than the reverse.
After many years of construction mangement in the Puget Sound area, I would say that $70-100/hr is a fair price. It is up to you if you want to charge a fee for "in and out". For say, three acres travel would be justified. For a hundred acres, you should probably eat travel.
/ How much to charge/ #9
i would not touch that job with a tractor your size for a few reasons.1 your tractor way to small HP wise.2 you have no idea what is in that pasture.3 that could be some tall heavy stuff your shredding.
/ How much to charge/ #10
I mow with my Boomer 8N 50 HP (40 HP PTO) and a 6' cutter at 3 MPH (per speedometer) on cruise. I overlap the width of the rear tire to get a good smooth cut, 80% efficiency. My pasture was originally a hay meadow. I can mow about 1 acre per hour.
Can you mow 100 acres with your tractor? Probably so. It will take much more than a weekend, lots of time and fuel, and contingencies for breakdowns which happen mowing unknown areas. Will it be worth the time, wear and tear on tractor and equipment, and expenses? Depends on what the owner is willing to pay.
That's just enough information to turn the job down. I think I'll pass and recommend he find someone with swather and baler.
Thanks guys.
/ How much to charge/ #12
For the smaller stuff that I usually get, I get in the range of $75-100 per acre. That includes travel and all so the bigger the lot the less per acre. Even if you were to drop to $40 per acre which is extremely cheap, that would be $4000. It may be worth spending a week out there on the tractor- I know I would do it. I would even burn a week of vacation to get it done. That's just me though, and I doubt the guy would be willing to pay that. He would be better off finding someone with a 20ft batwing and a 150hp tractor that could do it in a day.
/ How much to charge/ #13
Yup. Agree 100%. Also, an inexperienced operator might just roll the whole **** thing down a hill.
Any way, I told him I could mow it for him, but I'm not sure how long to estimate for it, and how much to charge. I have a 27 HP Kubota and a Deere 5' brush mower. I was thinking I could get it done over a weekend, but I'm not sure since I've never mowed that much land.
I have a 25 hp Bobcat and a 5' brush mower, so I'm pretty much in the same boat as you. I do about an acre an hour. I can go a little faster if the property is reasonably flat and has been hogged somewhat recently, but that is hardly ever the case for jobs like this. Usually, it's very overgrown. Because of that, you have to go much slower than a "mowing calculator" would suggest, because you're looking for debris in the weeds, finding boulders and rocks that you have to mow around, and so forth. Also, if the property is not dead flat, you are going to find spots that are steep enough that you may not be able to make the ideal approach--e.g. you have to drive up and down instead of across, or something--and that is going to further slow you down.
At 8 hours a day, that is about a 12-13 day job. I estimate that I burn about a gallon of diesel an hour (a little less, but it keeps the math simple). I also estimate about a dollar an hour towards my next 400-hour service. So that's maybe $4.50 an hour in cost just to keep the tractor running--bare minimum. Add in the potential for you to damage your tractor or mower, and I just round up to $10 an hour in equipment costs. Add on top of that what you think your time is worth, multiply by 100 hours, and away you go.
There are some on here who would say that the 1 acre per hour estimate is too conservative. IMO, it very much depends on the nature of the job. If it is head-high weeds, there is no way you can go at full speed, even if your tractor and your mower are big enough to handle the volume of material, because you are not going to want to charge blindly ahead. You may run into a ditch or a big chunk of cement or who knows what? If you had a very WIDE mower, then things might go faster, because you could still go at a safe speed, and cover more ground. I have only been bush-hogging for a little while, but one thing I have learned is that you seldom get asked to mow somebody's field that's been regularly maintained. Usually, it's some field that nobody has touched in six months, a year, or maybe more. The brush is 3'+ and you can barely see where you're going, and I just look at the mowing calculator that says I can do 3 acres an hour and laugh, and laugh, and laugh.
/ How much to charge/ #14
Yup. I charge $50 an hour, and I guarantee at least 1 acre per hour. At that rate, the job would be $5000. I'd probably cut the guy a discount for volume, and knock it down to maybe $3k, which isn't bad money for a couple weeks of work. That's extremely cheap for this kind of work, but still way out of most people's league.
Thing is, the guy with the 20ft batwing, if he's smart, he's still going to charge in the same ballpark, because he knows who his competition is. And of course, he's got to cover maintenance on a much bigger piece of equipment.
/ How much to charge/ #15
Have a written contract saying there is nothing in the field. Ever run over a horse drawn plow with a bush hog? I have, if I had not had it written out I would have had to pay for a set of blades and a cut in the deck about three feet long. All in a "clean" pasture.:duh:
/ How much to charge/ #16
I'm thinking why in the world would he ask you do it with that small of rig. He needs to get some one with a 50hp+ tractor and at least a 10ft bush hog. That would get the job done and be cheaper in the long haul.
/ How much to charge/ #17
The problem with a written contract is that you can be held to it. For instance, say your tractor breaks down. You could be liable for renting a new rig, or hiring someone else.
There are ways to lessen your exposure due to mechanical failure and what not, but you need to remember that a knife can cut both ways.
That said, I am in favor of properly written contracts, insurance, and walking away from jobs that you can't make money on. I searched a number of threads on this forum where pricing for pasture and meadow mowing were discussed. I was appalled by the number of people mowing for as little as $15.00/acre or $25.00/hr. As a business, it isn't worth bidding against those people, because they are operating on a deficit, whether they know it or not
/ How much to charge/ #18
I'd guess this is a situation to walk away from. He won't want to pay what it's worth for your time plus wear and tear and even if he does, these this wind up with unhappy endings. Either he will find some reason to be unhappy or you will wind barb wire around the PTO shaft and snap a gear or some other crazy thing worth $2,500. Plus you have no insurance, he'll claim his payment to you as a deduction, you won't claim it as income and it goes downhill from there.
/ How much to charge/ #19
Rock knocker It depends on the contract. In mine it just said he guaranteed the field was clear of things that would damage my tractor\ bush hog and agreed to pay damages.
/ How much to charge/ #20
He probably just doesn't realize how big a job it is. One other thought: are you sure his 100 acre estimate is right? I always check against Google Earth if I can.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
JOHN DEERE 5403 TRACTOR (A64280)
JOHN DEERE 5403...
2011 INTERNATIONAL TERRASTAR SERVICE TRUCK (A64276)
2011 INTERNATIONAL...
