How Much Front Bumper Weight?
/ How Much Front Bumper Weight? #1
Stoner
Florida
I have a New Holland TC30 tractor and I recently purchase a Rhino 6ft finish mower. The Rhino mower is built with some heavy gauge steel. When I used the mower for the first time I found when going up a hill the front end of the tractor would sometimes raise the front wheels off the ground. Also, making turns was not as easy as be. I was thinking about adding weight to the front bumper. I was thinking about 100lbs may solve the problem. What is your experience and thoughts? Thanks.
/ How Much Front Bumper Weight? #2
That will certainly help. When I run my light duty rotary cutter on my JD790 without the FEL, I put five 40 pound weights on the front. It is fine, but still a little lighter in the front than with the FEL in place. If 100 turns out to be light, add some more!
/ How Much Front Bumper Weight? #3
I had a similar problem with front tires not gripping during snow removal and made a bracket that holds 5 hanging weights. Each is about 30# totaling 150. It has helped put more weight on the tires.
/ How Much Front Bumper Weight? #4
I carry 250lbs of suitcase weights on the front of my Kubota B2910 when using my Brush Cutter or Tote Box. Makes life a lot easier!! :)
/ How Much Front Bumper Weight? #5
Stoner-
I have a L3830 Kubota and the dealer sold me 4 55lb suitcase weights to use when I run my 5ft Woods rotary cutter. The 220lbs balances the 550lb cutter very nicely. I think you will find it easier to run the tractor with ample front weights.
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Toro Groundmaster 580-D Rotary Mower (A66285)
Toro Groundmaster...
2011 Nissan Juke AWD SUV (A64557)
2011 Nissan Juke...
