How much???? B2920
/ How much???? B2920 #1
iplumb
Mason MI.
B2920
What is a GOOD price for a B2920 witha FEL & MMM ? Thanks Guys. Ready to buy...Want to think I'm getting a good deal!
/ How much???? B2920 #2
Well iplumb.............I would say that you would expect to pay between $17,500 and $18,000 for a B2920 with options..........including a block heater and ballast. Have you shopped around yet?
So is a block heater necassary? I do live in Michigan:D But I only have to plug my truck in a few times a year. I guess what I'm trying to say is in an unheated attached garage would I need it? How hard are they to add? Thanks
The dealer doesn't do rim saver:eek: They have a tire company come it to do it, It this typical?
Oh, and how much is a block heater? Does anybody know the watts? And how much for ballast? Thanks Guys
/ How much???? B2920 #5
It depends on your winter temps if you need a block heater. Whenever it gets below freezing I like to plug in the tractor. I guess it is just better on the motor not having a cold start. The machine with the glow plub system will start in pretty much sub zero temps as long as you battery is good. The ballast is a counter weight for your loader operation and I believe it says in the owners manuals that if you have a loader you are required to have ballast for stability purposes. I think the ballast would run like $200 and anther $75 - $100 for a heater installed. A guy could do it himself but just as easy to let the shop handle it in case there is a problem. Hope this helps.
/ How much???? B2920 #6
My dealer threw in the ballast box for free. For B-series tractors the box calls for 500lbs of weight. A box blade makes good ballast and is a lot more useful than the beer cooler.
/ How much???? B2920 #7
My suggestion is just go with tire ballast and then it is always there and you don't have to mess with putting on and taking off the ballast box.
/ How much???? B2920 #8
Smaller dealerships may not do the rim guard themself because it does involve some overhead and expense getting set up. So in otherwords, having a tire dealer do the ballast it not uncommon.
/ How much???? B2920 #9
True, but I don't want to mow with loaded tires.
/ How much???? B2920 #10
I think my brother in law paid $17,200 plus tax for a B2920, FEL, 60"MMM and new 52" Landpride tiller exactly one year ago.
Wow! do you know what dealer? Thanks
2007 Dodge Ram 1500 Pickup Truck (A61573)
2007 Dodge Ram...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
iDrive TDS-2010H...
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
