Tractor Sizing How important is rear diff lock on CUT?
/ How important is rear diff lock on CUT? #181
Split brakes is a system made to ensure that your tractor tips over when applied during a turn at (for a tractor) high speed:cool2:
Actually a germ of substance along with the wise-guy comment. Slowing the rotating speed of one wheel serves to increase the speed at which the other wheel rotates. If you're not prepared for it, that can make for some pretty sporty turns if you're bushhogging, etc.
/ How important is rear diff lock on CUT? #182
:laughing::laughing::laughing:
Actually true. Anybody here forget the brakes were split when they put a old high CG farm tractor in road gear and then tried to stop? Not fun (though it didn't flip, thank goodness). I always check the brakes now.
However, being able to brake each wheel separately is really useful, especially with a bigger machine.
/ How important is rear diff lock on CUT? #183
I just wish the BX1500 had them. On hillside use you learn that the front wheels arent turning fast enuf to assure they pull in turning. The sliding due to them being pushed will foil an uphill turn.
/ How important is rear diff lock on CUT? #184
You can't lock the brakes together on some of the old tractors which most of them barely had any brakes.
/ How important is rear diff lock on CUT? #185
I had a neighbor with old AC tractor with split hand brakes. That was a fun tractor to stop on a hill
2002 International 9200i Truck (A61307)
2002 International...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
