Tractor Sizing How important is rear diff lock on CUT?
/ How important is rear diff lock on CUT? #181
Split brakes is a system made to ensure that your tractor tips over when applied during a turn at (for a tractor) high speed:cool2:
Actually a germ of substance along with the wise-guy comment. Slowing the rotating speed of one wheel serves to increase the speed at which the other wheel rotates. If you're not prepared for it, that can make for some pretty sporty turns if you're bushhogging, etc.
/ How important is rear diff lock on CUT? #182
:laughing::laughing::laughing:
Actually true. Anybody here forget the brakes were split when they put a old high CG farm tractor in road gear and then tried to stop? Not fun (though it didn't flip, thank goodness). I always check the brakes now.
However, being able to brake each wheel separately is really useful, especially with a bigger machine.
/ How important is rear diff lock on CUT? #183
I just wish the BX1500 had them. On hillside use you learn that the front wheels arent turning fast enuf to assure they pull in turning. The sliding due to them being pushed will foil an uphill turn.
/ How important is rear diff lock on CUT? #184
You can't lock the brakes together on some of the old tractors which most of them barely had any brakes.
/ How important is rear diff lock on CUT? #185
I had a neighbor with old AC tractor with split hand brakes. That was a fun tractor to stop on a hill
Aluminum Fifth Wheel Tripod (A61166)
Aluminum Fifth...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
INOP/NON-RUNNING 2000 Sterling L9500 Cab/Chassis Series Truck, VIN # 2FZXEWYB3YAG90325 (A61165)
INOP/NON-RUNNING...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
WHEEL BARROW (A62131)
