How hot is it?
/ How hot is it? #122
After last week's heat index hitting 116F during the day, yesterday morning felt like the first day of Fall. This morning's temp in Middle TN was 58F.
/ How hot is it? #123
It seems the weather is all over the place here in America this year. We (Michigan) started out very dry this spring - dry enough where the first cutting yield was less than normal. July was unusually wet and cooler affecting drying times and produce (vegetables) was behind a good three weeks as things were slow to ripen. August was wetter yet. It finally stopped raining long enough to get my round bales off the field and the mud was like spring mud. I talked to a fella yesterday from Kentucky and he said they had an excellent year there. Saw a man a week ago from Wisconsin and he told me it was very dry there all year
/ How hot is it?
We are finally under the triple digits in So Cal... predicted low 90s today and low 80s tomorrow. Now that's better!
/ How hot is it? #125
You seemed surprised by the weather.
This is a good example how the media now expects people to believe the weather needs to be a constant and predictable temperature with low severity from storms being the norm.
Weather has always been variable and it's always had severity as a constant.
Big climate has won. They have programmed the masses into a belief norm.
/ How hot is it? #126
I've spent a good amount of time outside year around for decades - the weather here in Michigan is anything but typical this year. I studied weather and know how to look for signs of rain and fair weather without any media - dont watch TV. Somehow the idea of being lumped in with "the masses" suggests that one is easily lead, simple or sheepish
/ How hot is it? #127
Wet today here close to Colton, OR . . . about 60* now at 2:10 pm.
/ How hot is it? #128
Still hot and dry here. It was still at 101* around 6pm here.
We also had the driest August on record with 1.10” recorded. The previous record was 1.40”. Average is somewhere between 6 and 7”.
Azaleas are dead, magnolia trees are dead, lawns are all dead.
/ How hot is it? #129
Lawns may come back… at least they do here.
I try to keep the back lawn going watering each of 3 zones 20 minutes 2x a week so one hour total twice a week.
Used 630 gallons per day for 57 days…
All in including meter fee and tiered usage totals $570.86
So $10 each and every day for city water with 90% going to summer landscape…
/ How hot is it? #130
We finally got about an inch of rain yesterday afternoon. It soaked into the ground quickly.
The heat is still on. Heat index was up around 109* after the rain.
/ How hot is it? #131
Heat index at 113.5 this afternoon. Still hot!!!
/ How hot is it? #132
I would have expected much higher humidity in Louisiana. Even up here it's been in the 75+% range this week.
/ How hot is it? #133
I don't know how accurate my little sensor is. I assure you the humidity stays above 70% more than below, especially this time of year. We get up to 90% fairly often
/ How hot is it? #134
Right after remotely turning HVAC on in car yesterday. Thats toasty.
/ How hot is it? #135
You could compare your sensor against the official humidity reported for your location. 44% would almost certainly have to be indoor humidity I would believe.
Our temps and humidity in middle TN dropped about 10 degrees in the past week.
/ How hot is it? #136
We are on the downswing of the heat here in the southeast, mid 80's until next week. Gonna be down in the mid to high 70's by Wednesday of next week. HALLELUJAH!!!
/ How hot is it? #137
64 here approaching noon.
/ How hot is it? #138
It's hot living in a corn field. Dew point was 85
/ How hot is it? #139
Well, your local weather station went from a low of 61% RH to a high of 99% today, so I suspect your little gauge needs calibration. Low cost humidity sensors are pretty notorious for drift. Some of the old dial style ones used a strand of hair wrapped around the spindle of the gauge.
Personal Weather Station Dashboard | Weather Underground
All the best,
Peter
/ How hot is it? #140
Finally some relief. It's 69* here now. Dewpoints have come down a good bit so there isn't much heat index the last 2 days.
It has been a brutal summer. Our local weather man said we have broken every heat record in the book this summer.
