How Hard to De-Green a Kubota MX5200?
   / How Hard to De-Green a Kubota MX5200?
Glad I asked.
   / How Hard to De-Green a Kubota MX5200? #23
If you're mechanically inclined, the pre-emissions tractors are said to be easy to fix. I can't verify that because I'm not.
The only way I buy used on something mechanical is if I really know and trust the seller. Sometimes with cars you can use your mechanic to check it out. I guess if you have an independent or small dealer, they may be willing to do that. We have one here.
   / How Hard to De-Green a Kubota MX5200? #24
Buy low hour machines that have grease in all the fittings and show no sign of abuse.
   / How Hard to De-Green a Kubota MX5200? #25
I also was apprehensive about the DPF, but as I said above, I up my RPMs to a 1200-1400 'idle' and use the 'Linked Pedal' from there that raises the RPMs to whatever is needed when I press the Go Pedal with my foot, unless I'm mowing/hogging, obviously..
I use the loader with forks and grapple *a lot* and this method has been working since I bought it in 2020, with my first regen at ~70hrs and then every 70-90 hrs after that. All but 2 have been when I was using the tractor and never even noticed that it was regen'ing except for the light being on. The 2 I did notice were because I was parking it while it was still going. No big deal at all..
   / How Hard to De-Green a Kubota MX5200? #26
DPF = Dummy's poor filter...lol Don't ever expect to get a deal on a pre 4 tractor as they are selling for top buck today.
My dealer told me that both of mine are worth at least what I paid for them new.
   / How Hard to De-Green a Kubota MX5200? #27
How high do you keep your RPM's in normal use?
Normal use for me means that there is a piece of equipment on the 3 point hitch and connected to the PTO. And to get 540 rpm at the implement I have to run the engine at just over 1800 rpm. The hydraulic system (front loader, 3 point hitch, remotes, even the steering) is also happier at higher rpms.
Running higher rpm on the emissions equipped machines doesn't mean you can't ever let it idle. Having the engine at idle for a few minutes while you are hooking up a piece of equipment, or doing something else, is no problem. Just don't let the tractor run at idle for an hour or more at a time. That lets the exhaust system cool way down and soot builds up quickly, causing buildup in the DPF and early regenerations.
   / How Hard to De-Green a Kubota MX5200? #28
Given that the emissions stuff can cost thousands to repair, how do you check a used tractor to see if it's going to fail soon? Running it for 200 hours to check is not practical, so what do you do?
No way I know of. But then, if these systems were failing all the time you'd see posts complaining about it on the tractor forums. Do a search and see how many you can find. No moving parts to go bad in the emissions system. The DPF system works by injecting extra diesel into the exhaust which gets it really hot and burns off the soot to clean out the DPF. That's all it is. As long as they are operated per instructions in the owners manual they will last thousands of hours.
   / How Hard to De-Green a Kubota MX5200? #29
I haven't noticed myself getting a faceful of soot with my current diesels, but then I sit in the seat while I use them instead of climbing underneath and putting my face next to the exhaust pipes.
So far, I have not had to deal with any of this unneeded equipment. Do people really have to sit around and do nothing while their tractors eat their own waste? That has to be a drag. Like charging a Tesla.
The whole "limp mode" business scares me. A buddy of mine has a worthless Mercedes that went into limp mode over and over for something like three years, and no mechanic could figure it out. I don't recall who finally fixed it.
It would be neat to find a pre-BS tractor, but it turns out other people were smart enough to hold onto theirs or buy them from other people as soon as they came up for sale. They are not easily found.
I'm one of the people who held on. My tractor is 25 years old, and if it had 45 or more PTO horsepower and a decent loader capacity, I would never replace it. It's kind of remarkable that Kubota thought 1500 pounds was enough for a loader. A less-powerful TYM lifts 45% more. Big difference when your main use for the tractor is moving logs.
My feeling about buying tractors with expensive, unnecessary gadgetry is like my feeling about buying used German cars. No matter how cheap they seem up front, they could be sources of huge regret when repairs are needed. And German cars and tractors often need repairs. If someone gave me a BMW for nothing, I'd sell it ASAP and buy a Toyota.
Nobody sits around during a regeneration. Just up the RPMs and keep working. In fifteen minutes it’s over. Never experienced limp modes and the other MX owners here are saying the same things.
If DPF is so trouble-free, how come pre-emissions tractors cost so much?
   / How Hard to De-Green a Kubota MX5200? #31
Because a lot of buyers are of the same mindset as you, even though it’s usually unwarranted. I mean come on, anything mechanical can break, but there’s no widespread pattern of this occurring with DPF except on a few problematic models.
   / How Hard to De-Green a Kubota MX5200? #32
When I read the headline I thought he was comparing it to a John Deere.
   / How Hard to De-Green a Kubota MX5200? #33
Because a lot of people are anti emissions. A classic car cost as much as a new car. Does it ride better? Does it get better mileage? Is it faster? Does it handle better? The answer to all of those questions is no. Your world your choice.
   / How Hard to De-Green a Kubota MX5200? #34
All used equipment prices have gone through the roof because of inflation. I have a MX5200 which is a beast of a tractor. If you find one at a reasonable price that has been well cared for, I wouldn't let it having a DPF system deter me from buying it.
I checked around for used TYM's, and it's like they don't exist.
The MX5200 I came across has 1500 hours, and they're asking $17,500, including a small bush hog.
   / How Hard to De-Green a Kubota MX5200? #36
What was it used for, which transmission and does it have a loader?
   / How Hard to De-Green a Kubota MX5200? #37
I suppose you could look for a used, older, pre tier 4 emissions tractor but the selection is limited and they're getting harder to find. It is a used tractor though, and you may also wind up with someone else's problem. Future repair expenses may not be any less than those which MAY occur on emission control systems.
To me anyway, owning a new machine is worth the VERY minor inconveniences associated with most tier 4 tractors.
To
   / How Hard to De-Green a Kubota MX5200? #38
Generally a new tractor or car owner is going to take the biggest depreciation if they decide to sell within a few years. I agree with 2manyrocks.
I paid $32k for my 2018 with emissions and 150 hrs, 3 rear remotes, gannon, and loader. The dealer quoted 48k for the same in 2022
The MX5200 is a great little tractor. My last tractor of 14 yrs was a beast :p
It's an HST machine. No idea what it was used for, but apparently mowing was part of the mix. It has a loader. Looks like it spend a lot of time outdoors.
I haven't looked at it. Just something that popped up on the web.
There are TYM 55-horse tractors out there for around $30K.
   / How Hard to De-Green a Kubota MX5200? #40
Sounds like you got your answer from the community. What you found is a good used tractor. By Good I mean a capable model produced by one of the best, if not the best, small tractor manufacturers going back 50 yrs at a fair price. Maybe you are unfamiliar with tractors. The big name brands like JD, Kubota, MF have been at the top for a long time because their machines stood the test of time.. You have to decide what you will expect of the machine. And what you want to spend. Then what compromises you are will to make based upon what is available. If you want new, TYM is a bargain. But is a bargain always a bargain? There are a lot of ways to make something cheaper that are not always good. Neighbor bought a less quality tractor the same size as mine but with a nice cab, stereo, air conditioning, and such. So far he bent the loader and a wheel...sounds like that is where they saved some money making it.
I put my money on Kubota for their reputation of durability and resale.
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
John Deere 4520 (A60462)
John Deere 4520...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A60429)
2014 CATERPILLAR...
