How Hard to De-Green a Kubota MX5200?
   / How Hard to De-Green a Kubota MX5200?
I haven't noticed myself getting a faceful of soot with my current diesels, but then I sit in the seat while I use them instead of climbing underneath and putting my face next to the exhaust pipes.
So far, I have not had to deal with any of this unneeded equipment. Do people really have to sit around and do nothing while their tractors eat their own waste? That has to be a drag. Like charging a Tesla.
The whole "limp mode" business scares me. A buddy of mine has a worthless Mercedes that went into limp mode over and over for something like three years, and no mechanic could figure it out. I don't recall who finally fixed it.
It would be neat to find a pre-BS tractor, but it turns out other people were smart enough to hold onto theirs or buy them from other people as soon as they came up for sale. They are not easily found.
I'm one of the people who held on. My tractor is 25 years old, and if it had 45 or more PTO horsepower and a decent loader capacity, I would never replace it. It's kind of remarkable that Kubota thought 1500 pounds was enough for a loader. A less-powerful TYM lifts 45% more. Big difference when your main use for the tractor is moving logs.
My feeling about buying tractors with expensive, unnecessary gadgetry is like my feeling about buying used German cars. No matter how cheap they seem up front, they could be sources of huge regret when repairs are needed. And German cars and tractors often need repairs. If someone gave me a BMW for nothing, I'd sell it ASAP and buy a Toyota.
   / How Hard to De-Green a Kubota MX5200? #12
Not sure what your statement means. If you are talking about the regeneration process, you have the wrong idea. My Kubota M7060 is 9 years old now and only once in those 9 years have I had to "sit around and do nothing" while the regen process took place, and that's only because the automatic regen started just as I was about to park the tractor for the day. I throttled up past 2000 rpm, parked the tractor, and did something else for the 15 minutes it took to complete the regeneration process, then turned it off.
The rest of the time, the only way I would know the tractor is going through the regen process is when the light comes on in the dash. I have to do nothing, just keep doing whatever I was doing with the tractor - the process is automatic and it takes from 10 - 15 minutes from the time the light goes on in the dash till the light goes off, indicating the process is complete.
Sure, it would be nice to not have to deal with this stuff. When I bought the tractor I was really apprehensive about the problems the emissions system might bring. But, other than remembering to not let the tractor idle for long periods of time, it has turned out to be a non-issue. I'd buy the same tractor in a heartbeat if I had to do it over again.
Oh - and most of us have tractors with exhausts exiting above the hood so yes, soot in the face is a thing.
How high do you keep your RPM's in normal use?
   / How Hard to De-Green a Kubota MX5200? #14
Agreed, do not buy a tractor thinking you will remove pollution control components. It's not a practical solution to your problem.
Buy an older tractor without the equipment. That said.
My 2018 MX5200 is the best running tractor I've had in the past 35 yrs. When I first got it the regen happened more often as I was not running at a high enough rpm.
Now a days I mostly work it at higher rpms (1500-2300) mowing and grading and I don't even know when it regens... GL in your search
   / How Hard to De-Green a Kubota MX5200? #15
To me, 1500 is about normal. The tractor moves fast enough, the noise is moderate, and the hydraulics seem happy. I would not like keeping a tractor's speed at 1800 or more all the time.
   / How Hard to De-Green a Kubota MX5200? #17
Then buy a used tractor from before they were put on. It will cost you basically the same price as a new one because of other people like you. Obviously, you can't handle the the complexity and will worry every time you use it. Besides one specific kubota and some of the LS tractors, I haven't heard of many problems with regen.
Hey, don't take forum posts personally. This is a friendly place.
   / How Hard to De-Green a Kubota MX5200? #19
Like @CloverKnollFarms mentioned, TYM models that have a TYM (formerly Kukje) engine don't use the computer in the same way other do. If you remove the filter, it just keeps working.
They don't regenerate often. Mine is at 70 hours or so and hasn't yet.
Other than those, you have to buy an old machine to avoid it.
TYM has made tractors for other brands that use that engine, too. (Bad Boy for sure).
Given that the emissions stuff can cost thousands to repair, how do you check a used tractor to see if it's going to fail soon? Running it for 200 hours to check is not practical, so what do you do?
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59575)
2016 KENWORTH T680...
