rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,656
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Yes, that is being pedantic. Solids, liquids, and gases all contain particles. By saying "convert to gaseous form" you are simply repeating my concern using different words. The concern is that the smaller particles are more biologically active than larger ones.Fair point. I suppose I'll just be pedantic and say that the purpose is not technically to make the particles smaller, it's to eliminate them completely, IE convert to gaseous form.
I'm also not really feeling your final point, to be honest. I run my Kioti at ~1500-1800 rpm usually. Is that much higher than an old tractor? Seems about the same to me.
Modern pickup diesels definitely rev out to some historically high rpms, but (IMO) thats for a broad high-power delivery, not just because of the DPF. They still have a huge low end torque plateau and are happy to chug along at low rpms while cruising also.
On the final point about operating RPM, I run my older diesels at 1200 to 1500 RPM when doing backhoe work and up to 1800 for loader and up to 2200 when traveling, But when there is no load demand, they automatically returns to idle. So the RPM often drops to about 800 to 900 when it is not doing work at all....even if I'm just backing away with a load or stopping to shift ranges or gears.
My friends Kioti is Tier IV, and it runs at about 1800 RPM at all times. Even when he steps off to load brush in the bucket. He says it is supposed to be run at that speed - something about idleing at low RPMs causing increased regens. I've heard others here on TBN agree. You may know more about that than I do. I know I rarely see Tier IV tractors idleing like the older ones do.
rScotty
