How do I adjust mower deck?
/ How do I adjust mower deck? #1
bobgshn
goshen, In
craftsman 917287050
I have a craftsman 18 HP 42" lawn tractor and it is cutting higher on the left side I have the height adjustment on 6 but it cuts the grass at 3". Can anyone help me?
/ How do I adjust mower deck? #3
:welcome: check with your manual. There should be something about height adjustment.
/ How do I adjust mower deck? #5
If it's like all the other Craftsman mowers I have seen, the deck is supported by a linkage on each side. Each one is independently adjustable so you can level it and overall raise or lower it so you get a usable range of heights with the controls.
/ How do I adjust mower deck? #6
In addition to the above, make sure that the air pressure in the tires is correct. A low tire will give you an uneven cut.
/ How do I adjust mower deck? #7
Adjust the linkages to get side to side level (blades pointing east/west) , then blades pointing north/south adjust the cut , the leading edge of the blade should be no more than 1/8 to 1/4 of an inch lower than the trailing edge , set like that will give a nice clean cut :thumbsup:
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
MAN BASKET (A64553)
MAN BASKET (A64553)
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
Husky 5000Watt Portable Gasoline Generator (A64553)
Husky 5000Watt...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
