Buying Advice How can you evaluate a 4310 without seeing it in person?
   / How can you evaluate a 4310 without seeing it in person? #51
Consider it good. That is a lot of money for a 4310. And any new tractor you'd get would probably have a 300CX too. The "C" has a higher lift capacity and is self-levelling.
In the current lineup the 33/3520 are closest to the 4310.
   / How can you evaluate a 4310 without seeing it in person? #52
the 3320 is closest to the 4300/4310 as far as engine and PTO HP. The 3520 is close to the 4400/4410.
   / How can you evaluate a 4310 without seeing it in person? #53
Thank you Roy. :thumbsup:
   / How can you evaluate a 4310 without seeing it in person? #54
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
Bell 1600 Gallon Nurse Trailer (A56436)
Bell 1600 Gallon...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
