How big is big enough?
/ How big is big enough? #1
dbs179
Hi all,
I have been on here before (last year sometime) and asked a few quesions and read some posts, but since I have been in my home a bit longer and come up with a few more projects, I am finally ready to buy a tractor.
Here is my situation. I have 8 acres of land. All of which is wooded with the exception of about 1-1.5 acres that are cleared for the house and lawn. My lot is very steep since I live on a ridgetop, except for the area where my house and lawn are. So I doubt that I would ever clear out any more land for lawn, since it would all be to steep to do much with. My drive way is gravel right now, but will be paved in the distant future. The driveway is about 900 feet long by 10 feet wide. Also I have several areas along it where I can easily pile snow in the winter.
So with all of that said, my basic needs are to mow 1 acre and plow 900 feet of drive way. I live in WV so our biggest snow falls are usually not more than 8-10 inches at a time, and even that amount is pretty rare. I also have some small landscaping tasks around the house, and some brush piles to clean up.
I went to the Kubota dealer in my area and they recommended the B7510 Turf Special with a 60 inch mid mount mower, a 12 inch back hoe, a 48" FEL and a 60" rear blade. The tractor looked nice, and seemed easy enough for my better half to do some mowing, if I were away and she needed to, so we both really liked this tractor.
Then I went to a Mahindra dealer and they recommended the 2615 with all of the same implements except for a rear finish mower instead of the mid mount mower. With the size of my lawn I would think that the larger size of this tractor as well as the extra lenght of the rear mount mower would be cumbersome to mow my yard. Also with the added weight, I was not sure if it would do more harm to the lawn than the lighter Kubota.
I do plan on visiting the John Deere dealer as well as the Farm Trac dealer, but I am unsure of the HP range that I really need. I want the tractor to do all of the things I need easily, but I don't want to pay for extra HP and size that I will never put to use. Is the 21HP of the 7510 enough for this type of work, or would I really benefit from the extra weight and horsepower of the larger tractors?
Sorry for the long post, I just wanted to be sure I didn't leave anything out.
Thanks for any information.
Dave
/ How big is big enough? #2
I'm not the expert that many here are, but it seems to me you have 2 different needs that one machine doesn't satisfy. Have you considered a snowblower instead of a snow plow? 900 ft driveway even with a 10" storm could get tricky. You could probably get away with the smaller tractor.
I really like my Simplicity Legacy XL. I mow about an acre also. I have the 60" deck and really is an overkill. Even though 27HP engine, this tractor is very manageable. Actually drives better than the 14HP garden tractor it replaced. It is also 4WD which sounds like it fits you perfectly with the hills and will be great in snow. Lots of attachments. (I got the 48"FEL for the landscaping stuff) Of all the ones I looked at, Kubota, JD, NH, and Cub Cadet, this was by far the best value.
Keep shopping.
I had thought about a snow blower, but with a gravel driveway, I'm not sure that would be the best way move it. The Kubota dealer suggested the rear blade for snow removal, and it seems that is what all of my neighbors use. As for the snow falls, last year we only had two major snow falls. Both of which were 4-6 inches. (I shoveled both of these by hand, and swore I would never do it again) It is rare that we get up to the 8-10. Maybe once a season. Usually we get 2-4, and the bigger storms lay 4-6.
But what I did get from your post was that you think the 7510 would be sufficient for all but maybe the heavy snow removal?
Thanks
/ How big is big enough? #4
Did you look at the BX23 when you were at the Kubota dealer? It sounds like a better fit for your projects, and may save you some $$ compared to the B7510 with a backhoe. It's also designed/engineered as a TLB.
Here's a recent discussion comparing the BX and B series tractors.
I think I did start out looking at the BX series, but after talking to the salesman, he showed us the 7510. The 7510 with the implements I wanted was in the price range I was looking for. So I didn't go back to the BX.
/ How big is big enough? #6
Have you looked at the Power Trac line of tractors? If not, take a look just for comparison.
Power Trac website.
I really like ours. It is small, lightweight on the lawn, very stable, and has front mounted implements that attach to the permanent front loader arms. So, besides loader buckets, you can put over 40 other attachments onto the unit as well. Snow plowing is one of the jobs where this unit excels. The front mounted power angle snow blade out front lets you plow quickly and stack the snow over 6' high.
You may also want to check out the Power Trac forum here, on TBN by clicking here.
Good luck in your search for the right tractor for your needs. /forums/images/graemlins/wink.gif
/ How big is big enough? #7
MossRoad is right about the Power Trac. Take a look at this discussion.
"funpilot" was pretty well decided on a B7510 until we turned his head to the world of PT's. /forums/images/graemlins/grin.gif
/ How big is big enough? #8
Given your land description and the amount of lawn that you have a Kubota BX or a MF GC 2300 would fit. They both have a low center of gravity with would be good for your steep hills. Either one should have plenty of power for the items that you mentioned.
I went over and looked at the power trac site. It looks like they are only sold out of one location? That is far to go to get a tractor. Otherwise they look like good machines. Some folks have mentioned the BX23 over the B7510. It looks like the BX does not have a true 3pt on the rear and can't accept some of the implements that the 7510 can. Is this correct? I really would like to be able to use other rear implements if the need arises in the future.
But back to the original question. Given the responses, I am guessing that the B7510 would be able to do what I listed power wise, but there may be a better match for my needs?
Again thanks for all the input
Dave
/ How big is big enough? #10
Factory direct. No dealers. Service it yourself or find local help. Parts available overnight from the factory, or ground shipped for less $$, but a few days.
As far as going to get it, they'll ship it to you, for a fee, of course. Mine was shipped from VA to IN overnight with two pallets of attachments for about $500.00(four years ago). Couldn't have gone to get it myself for that price.
/ How big is big enough? #11
Dave,
From what you describe you need something primairly to mow the lawn and be able to clear snow when necessary. Given this I think you are looking in the right direction. I wouldn't bother looking at anything over 23HP (or so) for these jobs because you will probably not need it for that work and the tractor will get too big for the yard (even some of the 25HP machines might be too cumbersome in the yard).
You mentioned your concern about the BX23 and "other rear implements". What you described above may lead you to a sub ~23HP machine but what type of future uses are you considering? If you want to push over and drag trees, dig long ditches and foundations, brush hog a field, drag a big box blade, etc. then you could probably do all of that quicker with a larger machine +25HP.
I looked at the BX23 and was very impressed. I really liked the 60" belly mower and the size of the tractor for keeping the yard cut and the standard attachments (FEL/BH) for the extra work. But depending on what future uses you may have it might not be a good fit for you.
I guess you just have to try to list all of your current and future uses and try to size the tractor appropriately.
Good luck!
/ How big is big enough? #12
</font><font color="blueclass=small">( I went over and looked at the power trac site. It looks like they are only sold out of one location? That is far to go to get a tractor. Otherwise they look like good machines. Some folks have mentioned the BX23 over the B7510. It looks like the BX does not have a true 3pt on the rear and can't accept some of the implements that the 7510 can. Is this correct? I really would like to be able to use other rear implements if the need arises in the future.
Dave )</font>
Just curious, but what kind of $ are you talking for the 7510 and attachments. May help to better answer you questions if value is important.
Mavrik,
I also like the BX23 after looking at it on the site. But the lack of some of the other implements, makes me think I may want to upgrad from it in the future. This is an item that I want to only purchase once if possible, so I want to have options in the future. Not that I see a need for it now, but eventually a post hole digger, and trencher may be nice to have. But more importantly, I am getting the idea that these "small" tractors can do alot of work. And I should be fine with a 20-25 HP machine no matter which one I choose.
Pheonix,
The Kubota dealer quoted me around $21,000 for the B7510 Turf Special with a FEL, Back Hoe, 60" MMM, and 60" Rear Blade. That was delivered with taxes and the tires filled. The Mahindra dealer quoted me $23,000 for their 2615 with a FEL, Back Hoe, 60" RFM and a 60" rear blade, only the 2615 did not include delivery. As far as money goes if the machine is going to do all I want it to in the immediate future and can possibly do a bit more farther down the line (i.e. other implements) then I can justify spending that kind of mony. So to me value is important, but only in the sense that I don't want to pay for more tractor than I would ever use or need.
I hope that made sense.
/ How big is big enough? #15
It is hard not to like the 'B' series for what you are doing... You could do a lot worse,.
I'm not really sold on the Kubota yet though. I did like it, and the Mahindra was so so. I still need to check out what the JD equivalent is and stop by the Farm Trac dealer. Although from looking around it seems that the Farm Trac is not such a popular choice.
I just wondered why the Mahindra dealer would recommend such a larger tractor than the Kubota dealer. It got me thinking that maybe the Kubota was to small.
/ How big is big enough? #17
Don't skip checking out the New Holland brand, either. They are fine machines and I found them more ergonomic than any other brand that I sat on. Test drive as many makes and models as you can and take as much time as you need to get the right machine for your needs. Many times we read about folks not getting the correct machine for their tasks and then they are disappointed. /forums/images/graemlins/frown.gif
We want you looking like this -> /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ How big is big enough? #18
dbs179,
I'm not sure exactly what you are referring to when you say "lack of .. other implements" on the BX, but the backhoe comes off very quickly and the lift arms go on, and "walla!" - you have a Category 1 three-point on the back.
Kubota sells a Kubota brand rear blade, box blade and tiller for the BX23, according to the website link (click on Attachments) provided above. I know that all sorts of other attachments are available for the BX series from third party vendors, including post hole diggers.
There may be some Cat 1 implements that won't work on the BX23, but I'm not sure about that.
edit: I found a discussion from last year about attachments that will/won't work on the BX line.
/ How big is big enough? #19
</font><font color="blue" class="small">( I went to the Kubota dealer in my area and they recommended the B7510 Turf Special with a 60 inch mid mount mower, a 12 inch back hoe, a 48" FEL and a 60" rear blade. )</font>
I looked at a 7510 and a Kioti CK20HST, The Kioti felt more comfortable to me. I have 22 hours on it now and it has performed flawlessly (as I would have expected)
The Kubota felt cramped, and the loader control felt high and out of place.
Jim
/ How big is big enough? #20
A 21 hp machine in a tractor, not lawn mower, will do everything you want. NH has the bitty boomers that a lot of people like.
One question, why the hoe? You state that you are going to do some small landscape projects, do you have any use for a hoe after that?
I have a friend that clears snow in New Hampshire with a 24HP Boomer and a back blade. One of my neighbors uses the 18 hp boomer for everything you suggested. A back blade will be plenty in West By God Va for moving snow. You include the loader and you are set.
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
40' Shipping Container (A64047)
40' Shipping...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63118)
2023 Kubota...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59910)
2022 GREAT DANE...
