Hour meter
/ Hour meter #1
bamawhiteboy
ATHENS
Case IH Farmall 55A
I have a 2012 Case IH Farmall 55A and nothing shows up on the hour meter. Can anyone advise me?
/ Hour meter #2
Does the tach work?
Sounds like you have an electrical problem since your flashers don't work either. Check the fuses.
/ Hour meter #3
For a moment I thought CCWKen was psychic. I was thinking how does he know his flashers don't work?!!! Then I saw the other post! :laughing:
/ Hour meter
Everything else works. Where are the fuses?
/ Hour meter #5
It is meter fault due to timer wire disconnection. Better to visit auto electrician.
/ Hour meter #6
I'm not familiar with your tractor but the owner's manual should have the location of fuses. Some maybe in-line behind the dash and some may be on a fuse block next to the battery or regulator (if equipped.) Some may behind a panel below the dash. This is one of those things that often cause people to respond, "RTFM". :)
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2018 F-150 4WD (A63689)
2018 F-150 4WD...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
Bulk Hog Feeder (A66408)
Bulk Hog Feeder...
