Hour meter
/ Hour meter #1
bamawhiteboy
ATHENS
Case IH Farmall 55A
I have a 2012 Case IH Farmall 55A and nothing shows up on the hour meter. Can anyone advise me?
/ Hour meter #2
Does the tach work?
Sounds like you have an electrical problem since your flashers don't work either. Check the fuses.
/ Hour meter #3
For a moment I thought CCWKen was psychic. I was thinking how does he know his flashers don't work?!!! Then I saw the other post! :laughing:
/ Hour meter
Everything else works. Where are the fuses?
/ Hour meter #5
It is meter fault due to timer wire disconnection. Better to visit auto electrician.
/ Hour meter #6
I'm not familiar with your tractor but the owner's manual should have the location of fuses. Some maybe in-line behind the dash and some may be on a fuse block next to the battery or regulator (if equipped.) Some may behind a panel below the dash. This is one of those things that often cause people to respond, "RTFM". :)
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2014 TEXAS PRIDE TRAILER (A65643)
2014 TEXAS PRIDE...
(12) Round Bales of Hay (A65640)
(12) Round Bales...
John Deere 230 Disc Harrow (A66285)
John Deere 230...
1995 INTERNATIONAL 4900 S/A SPREADER TRUCK (A64277)
1995 INTERNATIONAL...
