Hour meter
/ Hour meter #1
bamawhiteboy
ATHENS
Case IH Farmall 55A
I have a 2012 Case IH Farmall 55A and nothing shows up on the hour meter. Can anyone advise me?
/ Hour meter #2
Does the tach work?
Sounds like you have an electrical problem since your flashers don't work either. Check the fuses.
/ Hour meter #3
For a moment I thought CCWKen was psychic. I was thinking how does he know his flashers don't work?!!! Then I saw the other post! :laughing:
/ Hour meter
Everything else works. Where are the fuses?
/ Hour meter #5
It is meter fault due to timer wire disconnection. Better to visit auto electrician.
/ Hour meter #6
I'm not familiar with your tractor but the owner's manual should have the location of fuses. Some maybe in-line behind the dash and some may be on a fuse block next to the battery or regulator (if equipped.) Some may behind a panel below the dash. This is one of those things that often cause people to respond, "RTFM". :)
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
1999 International 5000 SFA Day Cab Truck, VIN # 1HTTWADR6XJ004085 (A65563)
1999 International...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2016 JEEP PATROIT (A59914)
2016 JEEP PATROIT...
