Horse Mat for Soft Snow Blade Edge
   / Horse Mat for Soft Snow Blade Edge #21
what, when, where, how, do i sent money order? ...what a great idea. need 6x84 piece right now!
only on TBN do enthusiasts have such great ideas.
   / Horse Mat for Soft Snow Blade Edge #22
I contacted RB Rubber, http://www.rbrubber.com/, they are a horse rubber mat manufacture, about getting a thicker mat. If you did not want to buy a large mat this may be another option.
The was the reply
Tom,
The thickest mat we manufacture is 3/4" thick. You could "glue" two mats together to make up a 1.5. Each section of 3/4" x 8" x 48" will be $5.34 FOB Oregon. You will need our Sico-Met glue to fuse the mats together which runs $10.00 per oz, one once covers 30 lineal feet. The freight charges will be based on the amount of matting you purchase.
The other option you have is to contact a conveyor belt company and see if they have remnants available in the thickness and length you will need.
Good Luck and let me know if I can help.
Sincerely,
Kelly Arnold
Pet & Ag Sales Manager
email: ag@rbrubber.com
I want to add the rubber to the bottom of my FEL, I do not think ¾" will be enough to clear the bolt heads, gluing a second piece on it another possible solution. Got to see if I can find a local source for that Sico-Mat glue.
   / Horse Mat for Soft Snow Blade Edge #23
thank you, the 3/4 inch mat is very interesting, will call them tomorrow.
   / Horse Mat for Soft Snow Blade Edge #24
I would be interested in how you plan on adding this to your FEL. Have you decided how you are going to attach it?
   / Horse Mat for Soft Snow Blade Edge #25
I just ordered a 7foot x 1/2inch x 6 inche peice of high density plastic cutting edge specifically designed for scraper use (manure scraping and snowplow edges etc). Cost was $53 from Northbrook Farms. Their # was 877 624 2638, think the salseman was "Randy". Said the stuff was bulletproof and would hold up for a long time. Re the mays coming in bigger sizes - I have them in all 4 of our horse stalls and they are HEAVY. Wouldn't want to have to lug one around that's bigger than 4 x 6.
   / Horse Mat for Soft Snow Blade Edge #26
Bob,
I was thinking of drilling about 4-6 holes in the bottom of the bucket and counter sinking the heads of the bolts in to the rubber mat. If the grove is deep enough on the mat I may use that area to place the bolts into. Then I was thinking of gluing the other piece of mat on top of the bolts, or interlocking the groves together and then gluing. I am open to suggestions if anyone has any other thoughts or has been down this road before.
Tom
   / Horse Mat for Soft Snow Blade Edge #27
We're doing a project now that involves using a "people" elevator to move materials up and down over the next 4 months. We lined the walls with OSB, and were trying to figure out what to use to protect the 58" X 87" floor. After making several phone calls, I found a local supplier who just happened to have a 60" X 144" piece of heavy duty conveyor belt remnant. He sold it to me for $139 (he told me the price was only for the part I needed, not all 12'). We hauled it back to our shop for trimming it down to size, and I told the guys in the shop DO NOT trash the leftover belt. It is a little better than 1/2" thick and quite tough. One of the guys cut off what we needed for the elevator neatly with a carbide-tipped blade in a circular saw.............chim
   / Horse Mat for Soft Snow Blade Edge #28
<font color=blue>I was thinking of drilling about 4-6 holes in the bottom of the bucket and counter sinking the heads of the bolts in to the rubber mat. If the grove is deep enough on the mat I may use that area to place the bolts into. Then I was thinking of gluing the other piece of mat on top of the bolts, or interlocking the groves together and then gluing. I am open to suggestions if anyone has any other thoughts or has been down this road before.</font color=blue>
Use a greater quantity of smaller bolts (1/4-20, #10 or even #8) That way you can countersink within the 3/4" Saves you the hassle & expense of gluing.
Off the top of my head 6-10 small screws sounds about right. I can do a shear stress calculation if you really want me to/w3tcompact/icons/wink.gif
Be sure to use washers, preferably "fender" washers
   / Horse Mat for Soft Snow Blade Edge #29
great idea. maybe if you cut slots up and down, you could just loosen the bolts and slide it down a bit, instead of having to remove it and flip it
   / Horse Mat for Soft Snow Blade Edge #30
I found a truck tire recap on the side of the road, about 3/4" thick. Bolted to front of blade of cub cadet. Tried it on dry rough concrete and didnt leave a mark. Will try it out tomorrow night, snow in the forcast.
arkydog
DEUTZ MARATHON...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
