Horse Mat for Soft Snow Blade Edge
   / Horse Mat for Soft Snow Blade Edge #51
Here's another way to that skin cat. Buy 10" wide 2 ply belting from TSC. Cut/split belt to 5" wide. Drill holes and fit between the blade and the replaceable cut edge. The belt/wiper is about 1 inch lower than the replaceable cut edge.
The belt/scraper shows no wear, no noise in use. The wife is so happy with the results to her driveway! BTW, I was able to reuse the factory bolts/nuts. Cool Beans! /forums/images/graemlins/grin.gif
   / Horse Mat for Soft Snow Blade Edge #52
Great idea with the slip-joint pliers. The mat is so heavy it is hard to hang on to and move. The pliers should do the trick /forums/images/graemlins/laugh.gif
PJ
   / Horse Mat for Soft Snow Blade Edge #53
A friend got me a piece of heavy conveyor belt approx. 1/2" thick. I cut it to size with a utility knife and drilled holes in it. I made it about 3" longer than the metal cutting edge and it doesn't bend a bit.
   / Horse Mat for Soft Snow Blade Edge #54
Thats a super idea
   / Horse Mat for Soft Snow Blade Edge #55
Tom,
Where did your friend go to find a piece of conveyer belt?
OkieG
   / Horse Mat for Soft Snow Blade Edge #56
Does anyone have experience to know if these rubber type edges remove much pea gravel on top of a seal coated driveway? I always have to have the metal plow blade about 3/4 to 1 inch off the ground. Wish I could get closer. Thanks
   / Horse Mat for Soft Snow Blade Edge #57
Let me put it this way, my driveway is asphalt but on the end its gravel. With the horse mat I have not moved hardly any gravel from the driveway. Also when I plow off the driveway into the grass it does not damage the grass edges.
PJ
   / Horse Mat for Soft Snow Blade Edge #58
When plowing my in-law's and neighbor's bluestone gravel drives, I use the rear blade with the rubber edge and don't move much gravel. When I have done this, the ground was pretty frozen and the drive was frozen too.
Mark
   / Horse Mat for Soft Snow Blade Edge #59
</font><font color="blue" class="small">( Tom,
)</font>
He works at an asphalt plant. It was a piece they were throwing away.
   / Horse Mat for Soft Snow Blade Edge #60
Channel-locks is what I meant to say. The offset head, coupled with the ability to match the thickness of the mat gives you a good grab.
Yankee Bill
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
PALLET FORKS (A58214)
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
