Horse Mat for Soft Snow Blade Edge
   / Horse Mat for Soft Snow Blade Edge #51
Here's another way to that skin cat. Buy 10" wide 2 ply belting from TSC. Cut/split belt to 5" wide. Drill holes and fit between the blade and the replaceable cut edge. The belt/wiper is about 1 inch lower than the replaceable cut edge.
The belt/scraper shows no wear, no noise in use. The wife is so happy with the results to her driveway! BTW, I was able to reuse the factory bolts/nuts. Cool Beans! /forums/images/graemlins/grin.gif
   / Horse Mat for Soft Snow Blade Edge #52
Great idea with the slip-joint pliers. The mat is so heavy it is hard to hang on to and move. The pliers should do the trick /forums/images/graemlins/laugh.gif
PJ
   / Horse Mat for Soft Snow Blade Edge #53
A friend got me a piece of heavy conveyor belt approx. 1/2" thick. I cut it to size with a utility knife and drilled holes in it. I made it about 3" longer than the metal cutting edge and it doesn't bend a bit.
   / Horse Mat for Soft Snow Blade Edge #54
Thats a super idea
   / Horse Mat for Soft Snow Blade Edge #55
Tom,
Where did your friend go to find a piece of conveyer belt?
OkieG
   / Horse Mat for Soft Snow Blade Edge #56
Does anyone have experience to know if these rubber type edges remove much pea gravel on top of a seal coated driveway? I always have to have the metal plow blade about 3/4 to 1 inch off the ground. Wish I could get closer. Thanks
   / Horse Mat for Soft Snow Blade Edge #57
Let me put it this way, my driveway is asphalt but on the end its gravel. With the horse mat I have not moved hardly any gravel from the driveway. Also when I plow off the driveway into the grass it does not damage the grass edges.
PJ
   / Horse Mat for Soft Snow Blade Edge #58
When plowing my in-law's and neighbor's bluestone gravel drives, I use the rear blade with the rubber edge and don't move much gravel. When I have done this, the ground was pretty frozen and the drive was frozen too.
Mark
   / Horse Mat for Soft Snow Blade Edge #59
</font><font color="blue" class="small">( Tom,
)</font>
He works at an asphalt plant. It was a piece they were throwing away.
   / Horse Mat for Soft Snow Blade Edge #60
Channel-locks is what I meant to say. The offset head, coupled with the ability to match the thickness of the mat gives you a good grab.
Yankee Bill
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Mini Margaritaville Truck (A55853)
Mini...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
