Homemade Two wheel tractor
   / Homemade Two wheel tractor #11
Very interesting for sure. Will be keeping an eye out for progress reports. Like the actual building of parts, most people don't realize how much time is involved in designing and building components that come together as a finished product. No cad, just sketches and sittn'nthinkin'
I worked very well today. Began to make a transmission. Gears from a car and a motorcycle. Sheet metal case with a thickness of 15 mm.
20190227_095615.jpg 20190227_095623.jpg 20190227_095858.jpg 20190227_100846.jpg 20190227_103926.jpg 20190227_161155.jpg 20190227_161332.jpg
Diameter of shaft 47mm, gears from the car. The next step is to install the seals on the shaft.
20190301_110609.jpg 20190301_112113.jpg 20190301_120209.jpg 20190301_130041.jpg
   / Homemade Two wheel tractor #14
Very creative! Will it eventually be sealed and full of gear oil?
Yes, gears will be in oil. The transmission body will be airtight.
The box is ready. The next step is to fill it with gears
20190304_151937.jpg 20190305_172222.jpg 20190305_172916.jpg 20190305_174326.jpg 20190305_174336.jpg 20190305_174424.jpg 20190305_174446.jpg 20190305_174505.jpg
   / Homemade Two wheel tractor #17
odd, I don't see a keyway to attach the wheels, nor a groove for a c-clip, that's normally done with the shaft out of the transmission, so it can be put into the milling vise.. I hope you are not going to weld the wheels on!..
I am categorically against welding. All mechanisms must be collapsible. Later the shaft will have a keyway
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2019 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2017 John Deere 5090GN (A53317)
2017 John Deere...
Toro Workman (A56857)
