Homemade Two wheel tractor
   / Homemade Two wheel tractor #11
Very interesting for sure. Will be keeping an eye out for progress reports. Like the actual building of parts, most people don't realize how much time is involved in designing and building components that come together as a finished product. No cad, just sketches and sittn'nthinkin'
I worked very well today. Began to make a transmission. Gears from a car and a motorcycle. Sheet metal case with a thickness of 15 mm.
20190227_095615.jpg 20190227_095623.jpg 20190227_095858.jpg 20190227_100846.jpg 20190227_103926.jpg 20190227_161155.jpg 20190227_161332.jpg
Diameter of shaft 47mm, gears from the car. The next step is to install the seals on the shaft.
20190301_110609.jpg 20190301_112113.jpg 20190301_120209.jpg 20190301_130041.jpg
   / Homemade Two wheel tractor #14
Very creative! Will it eventually be sealed and full of gear oil?
Yes, gears will be in oil. The transmission body will be airtight.
The box is ready. The next step is to fill it with gears
20190304_151937.jpg 20190305_172222.jpg 20190305_172916.jpg 20190305_174326.jpg 20190305_174336.jpg 20190305_174424.jpg 20190305_174446.jpg 20190305_174505.jpg
   / Homemade Two wheel tractor #17
odd, I don't see a keyway to attach the wheels, nor a groove for a c-clip, that's normally done with the shaft out of the transmission, so it can be put into the milling vise.. I hope you are not going to weld the wheels on!..
I am categorically against welding. All mechanisms must be collapsible. Later the shaft will have a keyway
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
CASE IH 183 - 8R FOLDING CULTIVATOR (A52708)
CASE IH 183 - 8R...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
