HomeMade Quick Hitch hooks
/ HomeMade Quick Hitch hooks
Those certainly look like they would do the trick.:thumbsup:
Allthough I dont see the need for the peice on top of the pin. Unless your tractor has downforce on the 3PH. All the top of the hook does is keep the arms from falling off when lowered in float mode.
And I made mine weld on because I figured if I didnt, I'd loose them:confused2:
/ HomeMade Quick Hitch hooks #22
I just thought there might be some wear over time on the pin so I put the bars in to it would wear instead.;)
Possibly??? I dont know. Mine were just put on so I'll have to watch them and see. I see your logic. Not to hard to add to mine later if deemed necessary.:thumbsup:
/ HomeMade Quick Hitch hooks #24
I have the Carters, and in 125 hours no wear yet on the pin, I am not sure,but it may be a hardned pin, like a piece of drill rod or something.
James K0UA
/ HomeMade Quick Hitch hooks #25
James K0UA
Shouldnt even need to be a hardened pin. All it does is keep the arms from dropping off when in float mode.
My pins are pretty hard none-the-less. They are a 1/2" alloy bolt:thumbsup:
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
