Homemade garden mini tractor 4x4
   / Homemade garden mini tractor 4x4
Transmission repair. Replacement of all bearings, synchronizers, switching plugs and clamps, secondary and primary shafts. Also repairs locking rear differential
IMG_20170101_102424.jpg IMG_20170103_143830.jpg IMG_20170103_140935.jpg IMG_20170103_135214.jpg IMG_20170103_120627.jpg IMG_20170103_115223.jpg IMG_20170103_113943.jpg IMG_20170103_084251.jpg IMG_20170102_105636.jpg IMG_20170103_144706.jpg
   / Homemade garden mini tractor 4x4 #153
Hi guys. Sometimes there are moments when the four-wheel drive and locking rear differential can not do the job. Thinking hard to also install differential lock on the front axle. Or install a winch.
I would start easy and put the axle of your trailer all the way to the back, so a good portion of the weight rests on the tractor. Right now, you're just pulling dead weight. When you can put it on the tractor, it can help generate traction.
   / Homemade garden mini tractor 4x4 #154
+1, it's true. The more weight you'll have between rear axle of a tractor and an axle of a trailer, the more down pressure you will have on a rear axle of a tractor, what really generates better traction. But be careful not to exceed a distance between both axles, so your tractor's front end won't be lifted up.
   / Homemade garden mini tractor 4x4 #157
Innovative, good job making use of what you get can for parts. Is this a current upgrade you are making or one you did in the past?
Thank. This a current upgrade. I want to make cultivator, so need a new strong drive shaft.
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
78in Quick Attach Smooth Bucket (A57453)
78in Quick Attach...
Dewalt 14" Chop Saw (A59076)
Dewalt 14" Chop...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
