Homemade garden mini tractor 4x4
   / Homemade garden mini tractor 4x4 #182
Don't know if you noticed. Even the lathe/mill machine he makes his parts on looks homemade. You have to appreciate the determination and resourcefulness.
Eggzachery !
How about some background on yourself, and some pictures of your shop, maybe the farm and the area around you ?
Hello! A small assistant helps me build a house. Hydraulics work badly, the pressure in the hydraulic system is not enough. It is possible to replace the hydraulic pump.
   / Homemade garden mini tractor 4x4 #184
Dobre utra.
When a hydraulic pump gets worn, it can't pump up to full pressure. Check the filters first. Maybe fluid got too hot.
Good luck with the house.
   / Homemade garden mini tractor 4x4 #185
The problem might be a relieve valve in the joystick. Check if joystick get hot or emits sound.
My working day. The homemade tractor 4x4 helps me in the construction of my house.
Hydraulic Dingo 4in1 Bucket (A55272)
Hydraulic Dingo...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2008 Komatsu WB146-5 (A55272)
2008 Komatsu...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
