Homemade garden mini tractor 4x4
   / Homemade garden mini tractor 4x4
Transmission repair. Replacement of all bearings, synchronizers, switching plugs and clamps, secondary and primary shafts. Also repairs locking rear differential
IMG_20170101_102424.jpg IMG_20170103_143830.jpg IMG_20170103_140935.jpg IMG_20170103_135214.jpg IMG_20170103_120627.jpg IMG_20170103_115223.jpg IMG_20170103_113943.jpg IMG_20170103_084251.jpg IMG_20170102_105636.jpg IMG_20170103_144706.jpg
   / Homemade garden mini tractor 4x4 #153
Hi guys. Sometimes there are moments when the four-wheel drive and locking rear differential can not do the job. Thinking hard to also install differential lock on the front axle. Or install a winch.
I would start easy and put the axle of your trailer all the way to the back, so a good portion of the weight rests on the tractor. Right now, you're just pulling dead weight. When you can put it on the tractor, it can help generate traction.
   / Homemade garden mini tractor 4x4 #154
+1, it's true. The more weight you'll have between rear axle of a tractor and an axle of a trailer, the more down pressure you will have on a rear axle of a tractor, what really generates better traction. But be careful not to exceed a distance between both axles, so your tractor's front end won't be lifted up.
   / Homemade garden mini tractor 4x4 #157
Innovative, good job making use of what you get can for parts. Is this a current upgrade you are making or one you did in the past?
Thank. This a current upgrade. I want to make cultivator, so need a new strong drive shaft.
PALLET OF METAL AMMO BOXES (A58376)
PALLET OF METAL...
UNUSED SDLANCH 12' X 20' STEEL CARPORT (A58376)
UNUSED SDLANCH 12'...
Jumper Cables (A57149)
2015 Kenworth T370 Truck, VIN # 2NKHHJ7X3FM425081 (A57453)
2015 Kenworth T370...
2011 GMC Sierra 1500 4x4 Ext. Cab Pickup Truck (A56858)
2011 GMC Sierra...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
