Homemade garden mini tractor 4x4
   / Homemade garden mini tractor 4x4
Transmission repair. Replacement of all bearings, synchronizers, switching plugs and clamps, secondary and primary shafts. Also repairs locking rear differential
IMG_20170101_102424.jpg IMG_20170103_143830.jpg IMG_20170103_140935.jpg IMG_20170103_135214.jpg IMG_20170103_120627.jpg IMG_20170103_115223.jpg IMG_20170103_113943.jpg IMG_20170103_084251.jpg IMG_20170102_105636.jpg IMG_20170103_144706.jpg
   / Homemade garden mini tractor 4x4 #153
Hi guys. Sometimes there are moments when the four-wheel drive and locking rear differential can not do the job. Thinking hard to also install differential lock on the front axle. Or install a winch.
I would start easy and put the axle of your trailer all the way to the back, so a good portion of the weight rests on the tractor. Right now, you're just pulling dead weight. When you can put it on the tractor, it can help generate traction.
   / Homemade garden mini tractor 4x4 #154
+1, it's true. The more weight you'll have between rear axle of a tractor and an axle of a trailer, the more down pressure you will have on a rear axle of a tractor, what really generates better traction. But be careful not to exceed a distance between both axles, so your tractor's front end won't be lifted up.
   / Homemade garden mini tractor 4x4 #157
Innovative, good job making use of what you get can for parts. Is this a current upgrade you are making or one you did in the past?
Thank. This a current upgrade. I want to make cultivator, so need a new strong drive shaft.
2014 Dodge Journey (A55272)
2014 Dodge Journey...
Giyi Excavator Pallet Forks (A57149)
Giyi Excavator...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
2015 CATERPILLAR  XQ30 GENERATOR (A58216)
2015 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
