Hillside Compact Tractor?
/ Hillside Compact Tractor? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Looks like it does away with the 3PH.
I had never seen a hillside tractor like this and thought it would be of interest given all the discussions on roll overs.
/ Hillside Compact Tractor? #3
I'm curious about how the differential is set up as the wheels appear to be parallel, then how it adjusts for different slope angles -maybe some kind of swing arm or portal type axles? The triangular bit in the back appears to be a hitch but has some kind of linkage on both sides that looks like it connects to the axle. That's really neat! Thanks for sharing! Do you happen to know what the make and model is?
/ Hillside Compact Tractor? #4
There is more info on this link but it's Russian, since it was Russian concept. You may need translator if you want to dig deeper. The pictures are cool though and looks like there was a concept for the same system for a PTO powered dump trailer.
There is also a picture of the front of the tractor that Npalen showed. The front axle also has the same linkage to keep the wheels vertical.
Very interesting PDF! Thanks for posting!
Page 14 shows the hillside mechanism, page 22 a method to equalize dual wheel ground contact, page 83 a method to prevent gear shift change until clutch is depressed and page 92 is the steering clutch mechanism such as used on crawler tractors. Bedtime reading for us gearheads!
Anyone know of an app for translating a PDF?
/ Hillside Compact Tractor? #6
For more technical stuff, I've been very please with the Deepl translator app. I use it often on a German Branson forum and it's a lot better than Google Translator in that regard.
/ Hillside Compact Tractor? #7
You can copy the text into Google Translate, which generally gives pretty good results. Here's what it does with the part on pg 12 that describes how the wheels work:
"An example of a universal variant of a variable geometry undercarriage system is a mountain-flat modification of a tractor "Belarus" MTZ-82 and trailers to it (Figures 5–7). Its rear wheels are mounted on universal final drives (Figure 8), parts of which "fold" under the influence of the forces of hydraulic cylinders controlled by a tilt sensor, for example, pendulum type. This ensures the vertical position of the skeleton tractor, and also makes it possible to regulate its longitudinal bases. Such a tractor is indispensable when working on slopes, road slopes and is useful in the middle lane, where there are no strictly horizontal fields. For example, on plowing one wheel tractor rolls along the bottom of the previously laid furrow, which leads to to the deliberate lateral inclination of its frame together with the tractor driver."
/ Hillside Compact Tractor? #8
Curious if they use a pendulum like side hill combines for maintaining level while on a slope.
Combines have had side hill or hill side feature for years.
/ Hillside Compact Tractor? #9
Page 13 has diagrams of the gear arrangement:
Here's Google Translate's version of the caption:
"Figure 8 - Double folding gearbox mountain-flat modifications of the universal row-crop tractor "Belarus" with variable chassis geometry"
Item 12 appears to be the actuation cylinder with arms 10 and 11 keeping the driven axle constrained.
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
Aluminum Bell (A65583)
Caterpillar 215C LC Crawler Excavator (A66285)
Caterpillar 215C...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
