Hi-Flow Hydraulics
/ Hi-Flow Hydraulics #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
Is there anything wrong with running a standard flow attachment with the hi-flow circuit IF the attachment specs are within machines hi-flow flow and pressure? Some attachments just say Minimum Flow 13 GPM in the spec. So could this attachment run off either std. or hi-flow circuit?
/ Hi-Flow Hydraulics #2
NO, as long as you don't apply more GPM and therefore up the rpm of the hyd motor beyond the rated rpm limit.
Some attachments are designed for high flow, and must have the minimums to operate satisfactory.
Most hyd tool will operate at about any flow, but may not provide satisfactory results.
/ Hi-Flow Hydraulics #3
Agreed.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
2007 Ari-Hetra HDML-8 60,000lb Four Post Auto Lift (A66736)
2007 Ari-Hetra...
2025 Kioti CS2530 - like new!
2025 Kioti CS2530...
CAT 416F 36" Bucket (A68134)
CAT 416F 36"...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
