Hi-Flow Hydraulics
/ Hi-Flow Hydraulics #1
jgbanshee
Gold Member
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
Is there anything wrong with running a standard flow attachment with the hi-flow circuit IF the attachment specs are within machines hi-flow flow and pressure? Some attachments just say Minimum Flow 13 GPM in the spec. So could this attachment run off either std. or hi-flow circuit?
/ Hi-Flow Hydraulics #2
NO, as long as you don't apply more GPM and therefore up the rpm of the hyd motor beyond the rated rpm limit.
Some attachments are designed for high flow, and must have the minimums to operate satisfactory.
Most hyd tool will operate at about any flow, but may not provide satisfactory results.
/ Hi-Flow Hydraulics #3
Agreed.
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
(2) John Deere Row Markers (A64127)
(2) John Deere Row...
2016 Deere 180G (A60462)
2016 Deere 180G...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
Harrell 6710 (A64126)
