HF Predator engine on Troy bilt chipper shredder
   / HF Predator engine on Troy bilt chipper shredder #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
I bought a pre MTD Troy Bilt Super Tomahawk chipper shredder at Sears in the early nineties. Wore it out shredding the brush clearing areas of our lot. Have replaced flails and chipper blade. The 10hp b&S was always hard to start. From time to time looked for an electric start but came up empty. Recent looked at the HF engines and noticed they had electric starters. Picked up a Predator 420cc 13hp engine and it bolted right up using the the original bracket on the side of the motor. Shaft was 1 inch so pulley worked as well. Just used longer 5/16-24 bolts to maximize thread depth. Should I add some support brackets to the engine base? The original engine held fine for almost 30 years but it makes me a little nervous looking at that engine just hanging on the side. Wife wants a shredding station next to garden shed for shredding up clippings rather than putting out for trash.
   / HF Predator engine on Troy bilt chipper shredder #2
No need. Seen lots of engines using the mounts only around the output shaft with no issues. If your worried, make some sort of shelf bracket for it.
   / HF Predator engine on Troy bilt chipper shredder #3
Nice.
Looks like yours is direct-drive. Very interesting mount.
My Super Tomahawk has the maker name on it, WW Grinder. These units are great. Mine is probably from the 80s, and came with a 7 or 8hp flathead Breaks & Scrapum. I upgraded to a Honda GX340 from a dead generator. I made a different platform for the engine. I just toasted the belt this spring. Easy fix. I love the shredder.
The m/c wheels make it moveable.
2023 JOHN DEERE 2038R LOT IDENTIFIER 99 (A53084)
2023 JOHN DEERE...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
