Help!!
/ Help!! #1
PLOWER
Wisconsin
JD 4710 JD Lt133 JD 345
I had my JD dealer come get my 4100 to get a transmission heater and engine heater put on. When he brought it back I wasnt home, now I cant find the plug in for the engine heater. I found the transmission plug in, so wheres the engine plug in, or is it the same? Thanks
/ Help!!
Can any one help me on this? Thanks,
Cliff
I'm moving up to a 4710 or 5205!
/ Help!! #3
I wouldn't know about this heater stuff, like Harv had mentioned, it never gets cold enough to worry about that kinda stuff here. The cords that come with the Ford trucks to plug the diesels in, they just rot off. They never get used. I'm not even sure what or where it heats. Now,tell me, what do you know about the 4710. Wish they had some info on it. I'm just days from getting a Kubota L48 TL. I'll bet the 4710 ends up costing more or the same as a L48 TL. If the M4900 had HST, that would do it for me since even with a 5 cylinder diesel it costs less then the L48 TL. Rat...
/ Help!! #4
BLOCK HEATER for JD 4100(OPTIONAL)
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 19M6887 SCREW 2 M8 X 18
2 M800125 ADAPTER 1
3 M805828 GASKET 1
4 AM101390 ADAPTER 1
5 AR87184 COOLANT HEATER 1
6 AR87168 POWER CORD 1
7 AR87167 COOLANT HEATER 1
TRANSMISSION OIL HEATER
1 AR95434 WIRE 1
2 R34557 CLAMP 1
3 AR94493 HEATER 1
.. R44302 TIE BAND 2
/ Help!! #5
Plower,
On my 4600 it's on the left side under the engine molding if you're sitting in the tractor. Look way up under the molding. When I got mine that's where it was. It was wrapped up with a twist tie and not hanging down.
/ Help!!
I will have to look on thursday of next week since it isnt at my old house I will have to wait until we move. I couldnt see it I expected it to hang down like rat said, like on my Dodge Diesel. John you amaze me. Thanks cowboydoc I will check, It suppose to be cold in wisconsin now, I hope they didnt forget to put it on./w3tcompact/icons/smile.gif thanks,
cliff
/ Help!! #7
Plower - just looked at my 4700 - cord is hanging down like one would expect (left side) but runs up the side of the block to a fitting just below the exhaust manifold about mid point on the side of the engine.
/ Help!! #8
On my 4300, there are two separate plugs. One is visible hanging just under the left cowling, the other is a bit more forward and you have to kneel down and look up to see it. This is from memory.. I just peeked to make sure they had installed them as they promised. If you need more detail, post back and I'll look closer.
Bob
Bob Trevithick
/ Help!! #9
oops.. my memory failed me big time.
The engine heater is on the left about where I said, just hanging out slightly under the cowl. The trans heater, otoh, is back near the rear tire, way up under the tractor. It's hard to spot.
Sorry,
Bob
Bob Trevithick
/ Help!! #10
Hi, your idea is very interesting , I really like it. Thanks a lot
simulation taux banque credit immobilier de France - Credit immobilier de France, simulation credit immobilier. R駸ultat mitig pour le cr馘it immobilier de France.simulation taux banque credit immobilier de France
Cherry Wood Boards (A65640)
Cherry Wood Boards...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
