help! wrong excavator control pattern
/ help! wrong excavator control pattern #1
swick1
Platinum Member
WV
John Deere 1026R
I am renting a CAT 302.5c mini ex and the controls are "wrong". How do I switch it to John Deere controls?
/ help! wrong excavator control pattern #2
If it is at all possible (some of the mini hoes) have a hose block that has a lever to switch between the two different styles of controls.
Otherwise, the poor mans version you could switch the hoses!
/ help! wrong excavator control pattern #3
Maybe the John Deere controls are wrong. :D :D
Wedge
I'm at work now (just had it delivered). Hopefully I'll get it after an hour or so if it can't be switched. I'm digging next to a house, so this isn't a great place to get experience :). I guess i'll just dig my trench in the middle of the backyard first!
/ help! wrong excavator control pattern #5
Check under the floor mat I think... though looking online it appears that the pattern changer was optional - perhaps you don't have it.
/ help! wrong excavator control pattern #7
Rental yard should have changed it over for you. I learned on Deere and then a a contractor friend ask that I give his 13K Hitachi a whirl and I nearly put in ditch I was trying to fill in. From then on I ask the rental companies to make sure it's in Deere pattern. It is amazing how the mind- hand coordination sets in quickly. Hope you got the pattern straightened out...Gary
/ help! wrong excavator control pattern #8
Pattern changer is standard, and should be a valve under the platform, LH side. OMM should be under the seat.
Thanks guys... pictures forthcoming.
/ help! wrong excavator control pattern #10
Good day Swick1
Try this link may help go to excatech.org > Libary > H2 change the operating pattern
Regards
Uffex
/ help! wrong excavator control pattern #11
Good day Swick1
Regards
Uffex
By now I bet the mini excavator has been returned to the rental yard. The control pattern changer below the seat on the left side is easily switched to solve this problem,
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
ATS Power ATS-RT12R Mini Excavator (A66408)
ATS Power...
2018 KOMATSU WA270-8 WHEEL LOADER (A65053)
2018 KOMATSU...
DT200 Diesel Tank (A64194)
DT200 Diesel Tank...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
1,000-gallon Stainless Tender Tank (A66408)
1,000-gallon...
