help! wrong excavator control pattern
/ help! wrong excavator control pattern #1
swick1
WV
John Deere 1026R
I am renting a CAT 302.5c mini ex and the controls are "wrong". How do I switch it to John Deere controls?
/ help! wrong excavator control pattern #2
If it is at all possible (some of the mini hoes) have a hose block that has a lever to switch between the two different styles of controls.
Otherwise, the poor mans version you could switch the hoses!
/ help! wrong excavator control pattern #3
Maybe the John Deere controls are wrong. :D :D
Wedge
I'm at work now (just had it delivered). Hopefully I'll get it after an hour or so if it can't be switched. I'm digging next to a house, so this isn't a great place to get experience :). I guess i'll just dig my trench in the middle of the backyard first!
/ help! wrong excavator control pattern #5
Check under the floor mat I think... though looking online it appears that the pattern changer was optional - perhaps you don't have it.
/ help! wrong excavator control pattern #7
Rental yard should have changed it over for you. I learned on Deere and then a a contractor friend ask that I give his 13K Hitachi a whirl and I nearly put in ditch I was trying to fill in. From then on I ask the rental companies to make sure it's in Deere pattern. It is amazing how the mind- hand coordination sets in quickly. Hope you got the pattern straightened out...Gary
/ help! wrong excavator control pattern #8
Pattern changer is standard, and should be a valve under the platform, LH side. OMM should be under the seat.
Thanks guys... pictures forthcoming.
/ help! wrong excavator control pattern #10
Good day Swick1
Try this link may help go to excatech.org > Libary > H2 change the operating pattern
Regards
Uffex
/ help! wrong excavator control pattern #11
Good day Swick1
Regards
Uffex
By now I bet the mini excavator has been returned to the rental yard. The control pattern changer below the seat on the left side is easily switched to solve this problem,
2005 GMC Canyon (A57148)
2005 GMC Canyon...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2715SSFL (A61567)
2715SSFL (A61567)
Hydraulic Bottle Jack (A61573)
Hydraulic Bottle...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
