Help with Jinma 244E
/ Help with Jinma 244E #1
slugg
Jinma 244E
Hi
I have a problem with my Jinma 244E. It has started to leak oil. There is a leakage att the left side if the engine and in the middle, just behind the fule filter. Can someone help me?
Best regard slugg
/ Help with Jinma 244E #3
There is a forum here on TBN in regards to Chinese Tractors. Perhaps you might get more assistance by posting your thread on that forum. Good Luck. BTW:welcome:
Okey, thanks!!!
I found the leak, I will upload some pictures that shows the problem, I hope for warranty repair. Used the machine less than 35 h.
/slugg
Hi
Now I have uploaded some pictures to Pixbox. I have taken off Diesel pump. What has sealed the hole from the factory was a mixture of epoxy and chemical metal from the plastic padding. Now I'm wondering to plug the hole with a plug made ​​of brass. Or are there any suggestions from you on the forum.
Pictures See the link below.
Pixbox: sluggs album "Jinma 244E"
Best regards Slugg
/ Help with Jinma 244E #7
Okey thanks, I will :)
/ Help with Jinma 244E #9
Is it a pressurized leak (spraying) or just a slow leak?
How much clearance is there between the hole and the injector pump housing?
Here are some options that come to mind:
1. brass plug
2. install tapered neoprene plug (it would be similar to an oil proof cork stopper), then use a flat metal strap to hold it in place (use the threaded hole which is about 2 inches below the leak to secure the strap).
3. clean it well and mix up some JB weld epoxy and put in the hole
4. carefully stuff a small bit of rag down the hole and then try to tap it for a similar sized bolt. Removing the rag and using a magnet should pull out the metal shavings.
Hi
The distance between the pump and the hole is about 12 mm or half inch. I can not access to do a thread in the hole. But I myself have thought of doing a plug made ​​of brass. 0.02 mm larger than the hole, so I can knock it there and lock with locktite or similar.
/ Slugg
Hi
Now I have fixed the problem with the oil. I sealed the hole with a brass plug. So now the tractor is like new again. I also thank the manufacturer in China for the great support by e-mail.:thumbsup::D
/Slugg
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
S/A BOAT TRAILER (A63291)
S/A BOAT TRAILER...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
PALLET OF MISC WIRE, CHAIN, ELEC. MOTOR (A63291)
PALLET OF MISC...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
DMI ECOLO-TIGER 530B (A63291)
DMI ECOLO-TIGER...
