Help with Jinma 244E
/ Help with Jinma 244E #1
slugg
Jinma 244E
Hi
I have a problem with my Jinma 244E. It has started to leak oil. There is a leakage att the left side if the engine and in the middle, just behind the fule filter. Can someone help me?
Best regard slugg
/ Help with Jinma 244E #3
There is a forum here on TBN in regards to Chinese Tractors. Perhaps you might get more assistance by posting your thread on that forum. Good Luck. BTW:welcome:
Okey, thanks!!!
I found the leak, I will upload some pictures that shows the problem, I hope for warranty repair. Used the machine less than 35 h.
/slugg
Hi
Now I have uploaded some pictures to Pixbox. I have taken off Diesel pump. What has sealed the hole from the factory was a mixture of epoxy and chemical metal from the plastic padding. Now I'm wondering to plug the hole with a plug made ​​of brass. Or are there any suggestions from you on the forum.
Pictures See the link below.
Pixbox: sluggs album "Jinma 244E"
Best regards Slugg
/ Help with Jinma 244E #7
Okey thanks, I will :)
/ Help with Jinma 244E #9
Is it a pressurized leak (spraying) or just a slow leak?
How much clearance is there between the hole and the injector pump housing?
Here are some options that come to mind:
1. brass plug
2. install tapered neoprene plug (it would be similar to an oil proof cork stopper), then use a flat metal strap to hold it in place (use the threaded hole which is about 2 inches below the leak to secure the strap).
3. clean it well and mix up some JB weld epoxy and put in the hole
4. carefully stuff a small bit of rag down the hole and then try to tap it for a similar sized bolt. Removing the rag and using a magnet should pull out the metal shavings.
Hi
The distance between the pump and the hole is about 12 mm or half inch. I can not access to do a thread in the hole. But I myself have thought of doing a plug made ​​of brass. 0.02 mm larger than the hole, so I can knock it there and lock with locktite or similar.
/ Slugg
Hi
Now I have fixed the problem with the oil. I sealed the hole with a brass plug. So now the tractor is like new again. I also thank the manufacturer in China for the great support by e-mail.:thumbsup::D
/Slugg
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
Street Sweeper (A60352)
Street Sweeper...
Cat CB24B (A60462)
Cat CB24B (A60462)
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
