Help with idea for boom
/ Help with idea for boom #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Got bright idea to build a simple boom pole using just two pieces of angle iron forming a Tee. Would use top of quick attach or arch from PHD for pin attachment support. Won't take up much space and would be real easy to attach and remove, especially if I use quick attach frame. Has anyone done this or have sound ideas on size of angle iron and limits on length. I have serious eye problems and need to keep welding at a minimum so building one from scratch is not a good idea
/ Help with idea for boom #2
Your gonna something to prevent sideways movement. I made mine with three and it will lift good and not move sideways kinda like a tripod
Jim
/ Help with idea for boom #3
Maybe I am not understanding how you are wanting to apply the steel here, do you have a picture or sketch/drawing?
Angle iron can be usefull for building frame structures where the triangulation of the structure lends to it's strength. The only way I can think of to use it in a boom structure is in conjunction with a king post as a top strap(in tension), and a piece of flat strap would work just as well and weigh less. Angle iron twists and flexes too much in compression and shear(bend) to be usefull as a boom at a reasonable weight, and then not without closing it into a triangular tube(lots of welding). Round or box tube would be a far better choice for the entire structure, with my preference going to the round tube.
/ Help with idea for boom #4
I don't Understand either, Unless you intend to use the short part of the T as your lower links to the 3 point then a top link out to a 3rd point?
What I will say is these Items we build must be built to handle at least what we intend to put on them. If a boom pole breaks, the resulting injury even in deductibles will cost you more than either doing it right or buying a pre built unit.
I don't intend to lecture or state the obvious, I have just seen folks hurt and been hurt by cutting too many corners and unless you are talking about some real heavy angle, I don't think it will be built with enough safety factor for even the smallest of jobs, but I ain't no engineer either.... I don't have my book with me but the Machinist handbook or my engenieers pocket refrence will tell the strength of materials by size and thickness. I check it out if I ever have a question.
/ Help with idea for boom #5
I totally agree with this statement. I'm not an engineer type so I usually error on the surplus side. My projects are usually heavier than needed, but don't fail due to stress.
I need to spend my winter evenings reading up on metal strengths and specifications. But until then, I build overstrength out of my ignorance. :)
/ Help with idea for boom #6
ron-mar said it right, angle is good for tension (pulling apart) and slightly in shear but for compression or bending resistance it is not worth much...
mark M
/ Help with idea for boom #7
Mine is a simple and strong with a 4" pipe for the compression and 2- 2X2X1/4 angle for tension when I lift. I have picked up real heavy loads with it and it does work great
here is a picture Here
Jim
/ Help with idea for boom #9
ctpres said:
Kind of answers I was looking for. So that idea goes away.Thanks Guys
:D I think you did yourself a big favor.
Now build ya one
are you mounting this on the front or your 3 point? TSC has some real reasonable ones, food for thought
Jim
New 215/50-10 NHS tire on 5-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 215/50-10 NHS...
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
