Help with idea for boom
/ Help with idea for boom #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Got bright idea to build a simple boom pole using just two pieces of angle iron forming a Tee. Would use top of quick attach or arch from PHD for pin attachment support. Won't take up much space and would be real easy to attach and remove, especially if I use quick attach frame. Has anyone done this or have sound ideas on size of angle iron and limits on length. I have serious eye problems and need to keep welding at a minimum so building one from scratch is not a good idea
/ Help with idea for boom #2
Your gonna something to prevent sideways movement. I made mine with three and it will lift good and not move sideways kinda like a tripod
Jim
/ Help with idea for boom #3
Maybe I am not understanding how you are wanting to apply the steel here, do you have a picture or sketch/drawing?
Angle iron can be usefull for building frame structures where the triangulation of the structure lends to it's strength. The only way I can think of to use it in a boom structure is in conjunction with a king post as a top strap(in tension), and a piece of flat strap would work just as well and weigh less. Angle iron twists and flexes too much in compression and shear(bend) to be usefull as a boom at a reasonable weight, and then not without closing it into a triangular tube(lots of welding). Round or box tube would be a far better choice for the entire structure, with my preference going to the round tube.
/ Help with idea for boom #4
I don't Understand either, Unless you intend to use the short part of the T as your lower links to the 3 point then a top link out to a 3rd point?
What I will say is these Items we build must be built to handle at least what we intend to put on them. If a boom pole breaks, the resulting injury even in deductibles will cost you more than either doing it right or buying a pre built unit.
I don't intend to lecture or state the obvious, I have just seen folks hurt and been hurt by cutting too many corners and unless you are talking about some real heavy angle, I don't think it will be built with enough safety factor for even the smallest of jobs, but I ain't no engineer either.... I don't have my book with me but the Machinist handbook or my engenieers pocket refrence will tell the strength of materials by size and thickness. I check it out if I ever have a question.
/ Help with idea for boom #5
I totally agree with this statement. I'm not an engineer type so I usually error on the surplus side. My projects are usually heavier than needed, but don't fail due to stress.
I need to spend my winter evenings reading up on metal strengths and specifications. But until then, I build overstrength out of my ignorance. :)
/ Help with idea for boom #6
ron-mar said it right, angle is good for tension (pulling apart) and slightly in shear but for compression or bending resistance it is not worth much...
mark M
/ Help with idea for boom #7
Mine is a simple and strong with a 4" pipe for the compression and 2- 2X2X1/4 angle for tension when I lift. I have picked up real heavy loads with it and it does work great
here is a picture Here
Jim
/ Help with idea for boom #9
ctpres said:
Kind of answers I was looking for. So that idea goes away.Thanks Guys
:D I think you did yourself a big favor.
Now build ya one
are you mounting this on the front or your 3 point? TSC has some real reasonable ones, food for thought
Jim
Skeleton Backing Plate (A62679)
Skeleton Backing...
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A64553)
2016 JLG 800AJ 4x4...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
213064 (A64276)
213064 (A64276)
KIVEL PALLET FORK ATTACHMENT FOR MINI SKID STEER (A64553)
KIVEL PALLET FORK...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
