Quick Hitches Help with buying quick hitch.
/ Help with buying quick hitch. #1
JohnDeere4300
John Deere 4300
Hi everyone, first time post. Would like to say this is a great site with alot of great people. I have a jd 4300 with a fel, backhoe attachment, bush hog, turning blade and disc.
I would lke to get a quick hitch. Does it make it easier to hook up
attachments?
Which one is better, HF or JD?
Thanks Bill.
/ Help with buying quick hitch. #2
Thanks for the threads, Was alot of good information and great picture's. I will measure my attachments then buy one.
/ Help with buying quick hitch. #4
I have a 4300 with a Speeco quick hitch I bought at Agri supply about 6 years ago for 150$. Have since seen the same item at Northern or Harbor Freight for about 100$
Make sure you get the round spacers to go over the three pt hitch pins and prevent any wobble.
I also like the adjustable pin at the top. It is not fixed like JD was.
Also be sure to get the floating top piece to use on bush hogs etc.
I used to fight w/my equipment to hook up. Now it is a cinch.
Good luck
/ Help with buying quick hitch. #5
Thanks for the laugh :D:D:D
I will take my JD I-Match hands down any day.
/ Help with buying quick hitch. #6
And I would take the Speeco hands down any day.
The I match has a fixed upper hook. Even if the majority of your implements fit that fixed configuration, if you have a rotary cutter or finish mower that isn't quick hitch compatable, you'll need an upper "floating" link (like the speeco comes with). The fixed hook on the I match won't allow the use of that floating link. So, you'll have to spend a few hundred bucks buying kits to convert your mowers to quick hitch versions.
Good luck
Thanks for the information,
Thanks for the information.
Now with you kennyd, I guess that was a good laugh.:D:D:D
because we know that john deere is the best:D but i have gave my
two different JD dealers enough money. what ever i choose i promise
that i will use john deere (PAINT):D
I have never used any kind of hitch like that, and i would like to find
the easiest way to hook up on other attachments.
I have a plate in my left wrist with 8 screws for life and my left wrist
won't bend, It is very hard to hook up bush hogs, moldbord plow and
disc. (glad i don't need one for the backhoe)
Now which one of these to choose from and the best? :confused:
(1) John deere I-Match
(2) Speeco
(3) Pat's easy change system
(4)Delta hook Rapid hitch
(5) HF quick hitch
(P.S) are you still laughing? :D:D:D
2009 Blue Bird All American/ All Canadian School Bus (A61573)
2009 Blue Bird All...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
John Deere 4040 Tractor (A64047)
John Deere 4040...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
429835 (A61166)
429835 (A61166)
