Quick Hitches Help with buying quick hitch.
/ Help with buying quick hitch. #1
JohnDeere4300
John Deere 4300
Hi everyone, first time post. Would like to say this is a great site with alot of great people. I have a jd 4300 with a fel, backhoe attachment, bush hog, turning blade and disc.
I would lke to get a quick hitch. Does it make it easier to hook up
attachments?
Which one is better, HF or JD?
Thanks Bill.
/ Help with buying quick hitch. #2
Thanks for the threads, Was alot of good information and great picture's. I will measure my attachments then buy one.
/ Help with buying quick hitch. #4
I have a 4300 with a Speeco quick hitch I bought at Agri supply about 6 years ago for 150$. Have since seen the same item at Northern or Harbor Freight for about 100$
Make sure you get the round spacers to go over the three pt hitch pins and prevent any wobble.
I also like the adjustable pin at the top. It is not fixed like JD was.
Also be sure to get the floating top piece to use on bush hogs etc.
I used to fight w/my equipment to hook up. Now it is a cinch.
Good luck
/ Help with buying quick hitch. #5
Thanks for the laugh :D:D:D
I will take my JD I-Match hands down any day.
/ Help with buying quick hitch. #6
And I would take the Speeco hands down any day.
The I match has a fixed upper hook. Even if the majority of your implements fit that fixed configuration, if you have a rotary cutter or finish mower that isn't quick hitch compatable, you'll need an upper "floating" link (like the speeco comes with). The fixed hook on the I match won't allow the use of that floating link. So, you'll have to spend a few hundred bucks buying kits to convert your mowers to quick hitch versions.
Good luck
Thanks for the information,
Thanks for the information.
Now with you kennyd, I guess that was a good laugh.:D:D:D
because we know that john deere is the best:D but i have gave my
two different JD dealers enough money. what ever i choose i promise
that i will use john deere (PAINT):D
I have never used any kind of hitch like that, and i would like to find
the easiest way to hook up on other attachments.
I have a plate in my left wrist with 8 screws for life and my left wrist
won't bend, It is very hard to hook up bush hogs, moldbord plow and
disc. (glad i don't need one for the backhoe)
Now which one of these to choose from and the best? :confused:
(1) John deere I-Match
(2) Speeco
(3) Pat's easy change system
(4)Delta hook Rapid hitch
(5) HF quick hitch
(P.S) are you still laughing? :D:D:D
2201SFL (A64553)
2201SFL (A64553)
2001 Frieghtliner MT55 Chassis Step Van (A66736)
2001 Frieghtliner...
Unused 2022 Land Pride QH30 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2022 Land...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
