Help small dump trailer design: safe?
/ Help small dump trailer design: safe? #1
oldboyscout
ne PA
Kubota B2620
I need to build a small dump trailer. I'm thinking of 3 foot wide frame with 4 1/2' wide box over it. The box would be over the wheels which are 26 inch diameter. Will the center of gravity be too high?
Sure trac makes a trailer very similar to this but it's on smaller wheels. Unfortunately the smaller wheels cannot take brakes, which I really want.
/ Help small dump trailer design: safe? #2
This is for both on road and off road. The tires are the problem. The Suretrac has the small diameter wide tires, but they're so small that brakes won't fit. The smallest tires that will work with brakes are 6" larger diameter, but the same width, 205.
I could use something like that, except it can't have brakes.
/ Help small dump trailer design: safe? #6
Why can't it have brakes? couldn't it have surge brakes?
smallest wheels that will take brakes is 14"
/ Help small dump trailer design: safe? #8
What size wheels are they?
basically want to build this:
Sure Trac |
but on 26" tires instead of 20". so I can add brakes. I don't know if the center of gravity will be too high.
/ Help small dump trailer design: safe? #10
Can you make your bed sit in between the wheels but extend over the top of the like most ATV trailers?
Or put your wheels outside the bed?
Or use drop down axles?
I need to keep it small for use in the woods so I want the wheels underneath. I also need to use it on road for cargo-so a flat bed would be would best.
It needs to be small for off road use so I want the wheels under the bed. I also need to carry cargo On Road, so the flat bed would be most useful.
/ Help small dump trailer design: safe? #13
I think the centre (aussie way) of gravity would be high, but I think it also depends on the terrain, load and speed it is used at.
Maybe this is a silly idea but could you put a weight under the bed over the axle to help counter act thee effect?
Are you making it hydraulic dump (probably a silly question)?
I did do the added weight thing on another trailer that was too "tongue-light" when empty (axle too far back) and it did work, so I guess that's a possibility. It may be fine without it but I have nothing to compare.
/ Help small dump trailer design: safe? #15
I guess you could build it with that in mind so if need be you can add it. What type of loads will it carry off-road? terrain?
firewood and gravel. the terrain isn't good, but I can work around most of it.
/ Help small dump trailer design: safe? #18
Since you want to use the trailer on the road as well as the trails, maybe as fast as 55mph,
consider:
You can compensate for high COG by using sway bars, or starting with a PU truck
rear frame. Shock absorbers help here, too. Most trailers have neither. Trailer
tires work better than truck tires, too, due to the stiffer sidewalls.
My tanker trailer below has high COG, but it is built on a Ranger rear half, with the above
features. It also has brakes, but they are not connected. I know it does not dump,
but the estimated empty weight is 800#, and 150 gal of water pushes it to 2000#.
BTW, I also stole the Ranger's bed for the dump box base on my Suzuki Samurai dumptruck.
/ Help small dump trailer design: safe? #19
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2012 Ford Transit Connect Cargo Van (A64556)
2012 Ford Transit...
2022 EZ-GO ELITE...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
2007 Ford F-750 Chipper Truck (A64194)
2007 Ford F-750...
2011 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2011 UE...
