3-Point Hitch Help removing a King Kutter rotary cutter
   / Help removing a King Kutter rotary cutter
The salesman said the tractor we bought was too light for a front hay spear and I took him at his word.
   / Help removing a King Kutter rotary cutter #42
You moving round bales 650 to750 lbs front spear will work my kubota is about the same size I move large square bales 3x3x8 750 lbs....
   / Help removing a King Kutter rotary cutter #43
With the mower in the back, it should counter loader weight of a 4x5 round bale
   / Help removing a King Kutter rotary cutter #44
The rear carry will be a lot easier on the tractor, especially if the ground is rutted or rough.
   / Help removing a King Kutter rotary cutter #45
Donhite...I sit the front of the cutter on boards so you can move it side to side easily. Remove one side, slide the cutter, remove other side.
   / Help removing a King Kutter rotary cutter #46
Or better yet, carry one with a spear on the loader and one with a 3pt hitch bale spear :D
   / Help removing a King Kutter rotary cutter #47
Question, why would you buy a 3 point hay spear with a front end loader?
As far as the quick attach, I would not use it with a PHD.
You cannot use a 3pt. PHD with a 3pt. quick attach due to having to remove the top link in order to pin the PHD directly. Then the hoop is attached to the 3pt. arms.
   / Help removing a King Kutter rotary cutter #48
Bluesteel, I know you are right. I just didn't want anyone to think they could use a PHD with a quick connect. I am sure that there is someone out there that may think it or even try it.
Rooster Weathervane (A55853)
Rooster...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
John Deere 5055E (A53317)
John Deere 5055E...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
